Old 11-19-2002, 12:49 PM   #1
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
alternator brackets
mine is about trashed and it doesn't really fit right in the first place, i talked to summit and they have 2 kits that they will garentee fit but they are $160. i have a short water pump (which is being the sticky point, i know) headers, tall valve covers and a performer RPM manifold. alt on the drivers side. i couldn't afford to do change everything to long mount stlye when i put the motor in and now am debateing if i should do it now or spend the money on the short pump kit or see if there is a better third idea out there.
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 11-19-2002, 01:51 PM   #2
JimKshortstep4x4
Smile
Do you have the factory truck setup on there now?
Jim
Old 11-19-2002, 02:33 PM   #3
chevyhouse
chevyhouse's Avatar
yes it is the factory set-up, thats why it doesn't fit quite right. the alt is the only acc i have now but will be adding powersteering some day. thanks for the help
Kurt
03' Trailblazer
Old 11-19-2002, 07:35 PM   #4
bigjimzlll
bigjimzlll's Avatar
do a search on alan grove industrys...they have great products,,I have their short water pump alt brkt..like 75.00..its great
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-19-2002, 08:11 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
Sounds like junkyard time. I bought the brackets for alt. at a junkyard for $15 , and it came with the altanator. And i got the power stearing pump and bracket and hozes for $35.. I love going to junkyards and looking around.
good luck...
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 11-20-2002, 03:48 AM   #6
chevyhouse
chevyhouse's Avatar
tried the junkyards, problem is the tall valve covers, nothing stick had them so nothing stock fits over them, Bigjim do you have a website or anymore info on alan grove? i did a search and found nothing
Kurt
03' Trailblazer
Old 11-20-2002, 08:22 AM   #7
MOTHERTRUCKERS
We cut the alt bracket in the fat area about an 1 1/2" from the adjuster groove and add 1" to it, grind the welds and paint, powder coat or chrome it. Make sure when you weld it that it clears the alt fan.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 11-20-2002, 09:50 AM   #8
bigjimzlll
bigjimzlll's Avatar
http://www.streetrodcatalog.com/manu...e_sbcswp.shtml
couldnt find alan groves site...these guys sell the brkts for 80.00...alan grove must of gottten too big to sell out of theyre own site
jim
Anderson,CA
Old 11-22-2002, 01:38 PM   #9
Blue68
Blue68's Avatar
Try this on...It's a '98 350 setup out of a Z71 pickup. All the accessories and water pump. I've since replaced the fan shroud with a BB and it looks much better now.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 11-22-2002, 01:40 PM   #10
Blue68
Blue68's Avatar
oops, wrong pic...
Old 11-22-2002, 06:43 PM   #11
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
Alan Groves site is www.alangrovecomponents.com
GMC JUNKIE TOO is offline   Reply With Quote
