Old 09-22-2008, 04:13 PM   #1
my67chevytruck
Under Construction
my67chevytruck's Avatar
Motor mount / tower ?'s
Hello,
We have a father / son 67 swb c-10 build that we are getting ready to do a crossmember swap to a '72 for disk brakes. Will the 67 sbc motor stands/mounts bolt to a 72 crossmember? I am thinking they will but want to be certain. The parts truck had BBC motor stands originally. Thanks for any help you can provide, i want to make sure i have all the needed parts before i start the swap.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-22-2008, 04:32 PM   #2
Classic Bowties
Always on the hunt...
Re: Motor mount / tower ?'s
Yes, they used the same sbc tower from 67 to 72.
Classic Bowties is offline   Reply With Quote
Old 09-22-2008, 04:43 PM   #3
my67chevytruck
Under Construction
Thanks for the quick reply. Do the mounts separate from the tower, as i didnt see a bolt going through the rubber mount, but it was late when i looked. I may have more questions in the near future.
Thanks as always...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-22-2008, 04:55 PM   #4
Classic Bowties
Yes, the mounts are bolted to the block with three bolt and should unbolt from the towers by removing the single center bolt/washer on bottom side of stand, if they are 67-72 sbc towers.
Old 09-22-2008, 05:25 PM   #5
my67chevytruck
Under Construction
ok, thanks for the reply.I saw where it was bolted to the block with 3 bolts. I will go see if i can see the single bolt. so to pull the motor will i have access to unbolt the single bolt, or will i have to unbolt from the block? Excuse my ignorance, but I am trying to make sure i pull the motor/trans the most efficient way.
As always we appreciate your help.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-22-2008, 06:08 PM   #6
Classic Bowties
Just remove the single bolt running up thru the tower and into the mount/bushing, one on each side and you are ready to lift out.
Old 09-22-2008, 06:12 PM   #7
my67chevytruck
Under Construction
Thanks again Classic. We appreciate your help.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-22-2008, 08:32 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a couple photos to give you an idea.
This was on small block frame mounts, but they mount on there the same way
Old 09-22-2008, 11:13 PM   #9
my67chevytruck
Under Construction
Thank you longhorn. the pics help alot. Thanks to all, this board rocks.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
