Old 11-19-2002, 01:01 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
WANTED:3.73 Gears!!! Anyone
I have a 12 bolt diff. If anyone is wanting to sell pm me or post a reply...Thanks
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 11-19-2002, 01:05 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
are you looking for the ring and pinion and gear set? Posi?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-19-2002, 01:31 PM   #3
Shane
Shane's Avatar
You have a PM.....
Shane is offline   Reply With Quote
Old 11-19-2002, 01:31 PM   #4
chevjayfsd
Project 7dos
chevjayfsd's Avatar
I have 3.07's right now and the diff. is in perfect shape. And i need everything to just get the 3.73's in. I think i might spool the gears instead of posi, or if someone knows about a substitution for posi, that would be most appreciated
jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 11-19-2002, 01:51 PM   #5
mikep
Used to have a truck
mikep's Avatar
The conventional wisdom is that spools are only for the dragstrip. Since I have in the past driven a spooled vehicle on the street for 20,000 or so miles I can say that you can get away with it IF...
You have large tires with high sidewalls that will flex
You dont make sharp U Turns often
You dont drive in snow or rain or ice much . Better slow to a crawl around corners if you do.
You Dont use C Clip axles ( physically impossible anyway )
Fact is you stand a good chance of breaking your axles with a spool on the street. I was using 31 spline Currie axles and I still twisted them some. If they were stockers I would probably have broken them . Its not a good idea.
No truck :-(
mikep is offline   Reply With Quote
Old 11-19-2002, 02:47 PM   #6
brennecke
brennecke's Avatar
I have a set of 3.73 posi in a 6 lug axle. I'll trade you straight up for your 3.07 axle. You do the shipping.
Never tire of doing what is right II Thess. 3:13
Northeast Missouri
71 LWB original 350 3/speed
Soon to be 500
brennecke is offline   Reply With Quote
Old 11-19-2002, 02:58 PM   #7
chevjayfsd
Project 7dos
chevjayfsd's Avatar
I would But I don't have wheels for a 6 and i would rather have my 5's, And also have had a lot of feedback..
Thanks a million anyway
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 11-19-2002, 03:17 PM   #8
Gene
Gene's Avatar
Can't you guys just swap out the axles? You keep your 5 lug axles and swap rear housings and gears? I dunno just a thought, I am also looking for a 3:73 posi, mine is a 3:07 5 lug posi.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 11-19-2002, 05:04 PM   #9
Shane
Shane's Avatar
Did you get the pics I emailed?
Just wanted to make sure.....
Old 11-19-2002, 06:03 PM   #10
1971Stepside
Almost Satisfied
If you guys can work out a swap that is the best deal.......but....if you end up needing to buy gears I think I would spend the little extra and get new ones. I wouldn't think saving a 100 bucks on 30 year old set ups is worth it. I just bought an Eaton 3.73 Posi from Randy's Ring and Pinion for $270. They matched Tom's differential price...they are normally $340. I got the ring and pinion for $150 and the install kit for $80. So, for around $500 it is all brand new. I know that is a lot but there is zero worry with it. Just my .02....
And again, if a trade can be made then that would be cool.
Old 11-19-2002, 06:51 PM   #11
72MARIO
72MARIO's Avatar
I am o most positive that the axels will swap except if the rear end 's changed width in 71 . because they are both 30 spline axels . the posi carrier in my truck is from a 69. Good luck
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-19-2002, 07:15 PM   #12
chevjayfsd
Project 7dos
chevjayfsd's Avatar
I'm Confused!!!!!
Should i buy new or can i get by with used????
And what can i use besides Posi($$$$)
I can cut costs way down if i by used....
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 11-19-2002, 07:49 PM   #13
Shane
Shane's Avatar
I have heard Pro's and Con's with these....and I have no experience with these either, but Loc-Rite is an alternative to a "posi" unit.
http://www.4x4cyberstore.com/website/lockright.html
Now.....The New VS. Used - I would buy new peices if it was me.....because it is gonna cost ya to have used peices installed in your rear-end if you pay to have someone else do it ... and what if, after having them installed, you find out they are noisey (aka:worn)? Then you gotta pay again to have them re-done...
Why pay to have used parts put in, when you can spend just a little more and have new parts put in that you know are good. May cost a little less at first....but could cost more later.....that's a chance you take every time you buy used parts.....
I had rather spend a little extra on new....and know I am getting good parts....especially when you are talking about spending that kind of money.
Just my take on things......
