Old 09-22-2008, 10:49 PM   #1
drivethechevy
drivethechevy's Avatar
transfercase ?'s
ive been working on my new 68 k10 for the past couple weeks now and i have decided to find out exactly what im running underneath, here is a pick of the back of my t-case i was told that 68's had the rockwell 221, is that what i have of is this a different t-case if so what is it
thanks
nate
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 09-23-2008, 07:00 AM   #2
Blazer1970
Blazer1970's Avatar
Re: transfercase ?'s
That is a 221.
Blazer1970 is offline   Reply With Quote
Old 09-23-2008, 10:14 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Now that is interesting! Unless the pic is tricking me, someone has added an extended fill neck on the side of your transfer case so it can be over-filled.
Can you get a better pic of the left side of your transfer case where that pipe with the elbow and pipe with cap is located?
Before mine got low on gear oil and gernaded, I thought that something like that with a reservoir would be a great addition to a T221 to avoid problems when the gear oil gets low. I was thinking about something that would allow you to keep an eye on the fluid level.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-23-2008, 11:21 AM   #4
1969K10
1969K10's Avatar
Is there a hole in the floor of the cab to fill that pipe from??? It was such a PITA to fill it normaly, I can't imagine trying to get fluid into the 221 with that addition. Cool idea though!
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 09-23-2008, 10:19 PM   #5
drivethechevy
i will get a couple better pics of the tube up tomorow
the in the tunnel for the shifter was made bigger, im not sure why but it could have been for access to the fill tube i will get a picture of that aswell
Old 09-24-2008, 07:29 PM   #6
drivethechevy
here are a few pictures of the fill tube, i looked closer ate the tunnel and no it is not accessable from cab it looks like its just some treaded pipe that someone put in the tcase
Old 09-24-2008, 07:44 PM   #7
msgross
msgross's Avatar
check out my build thread for cleaner pics!
I'd like to see pics of another 68 K-10 though... not that many made or on the board....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-25-2008, 09:26 PM   #8
I imagine that tube could be filled with a pump set-up like at a lube place or service station.All this stuff is hard to fill at home for me.That sure is a good idea,though.
