Old 09-23-2008, 09:22 PM   #1
DANTIP
DANTIP's Avatar
Tilt Wheel Shift Indicator Light Bulb
Classic Bowties (Mel) wrote a very good procedure to change the shift indicator bulb in a tilt wheel. The procedure worked great but I cannot find in any manual (service or owner's) what the bulb number is. Many of the small bulbs are 194 but I would like to know if someone knows for sure. BTW I nearly broke my white plastic indicator off when I tried to take the PRNDL housing off. I used to wonder why most tilt wheel had the indicator broken off and now I know at least one of the culprits.
DANTIP is offline   Reply With Quote
Old 09-23-2008, 09:24 PM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Tilt Wheel Shift Indicator Light Bulb
That bulb is a 1445
KevsClassics is offline   Reply With Quote
Old 09-23-2008, 10:11 PM   #3
DANTIP
DANTIP's Avatar
The info I looked up on the 1495 claims it is a 28v bulb. I now suspect it is a 1445.
Old 09-24-2008, 08:51 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Dantip,
can you post the link to the htread Classic Bowties did on this???...thanks!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-24-2008, 09:02 AM   #5
DANTIP
DANTIP's Avatar
Here it is. The original question was related to a non-tilt fiber-optic line and morphed into info on changing the bulb in a tilt column. BTW this worked very well.
http://67-72chevytrucks.com/vboard/s...d.php?t=307100
Old 09-24-2008, 10:18 AM   #6
DANTIP
DANTIP's Avatar
The 1445 bulb works perfectly! I did however fail to make a mental note of the orientation of the slot in the metal bulb cover and had to use a mirror to figure it out during reassembly. This note should be added to the procedure. Thankfully this bulb is rated for 1000 hrs of use (should be good for the next 36 years or so). I could have changed 8 spark plugs in the time it took me to change 1 little light bulb.
Old 09-24-2008, 12:13 PM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks for all the help Mr. Dantip!!!!
Geoff with a G
Old 09-24-2008, 12:53 PM   #8
leddzepp
Moderator
leddzepp's Avatar
I am going to have to check mine out...it does not work either. It did for a while, but hasn't in years now.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-26-2010, 09:24 PM   #9
jondancer
i just changed mine, the bulb works, but it does not light up the indicator very well with that green piece on.
jondancer is offline   Reply With Quote
Old 11-26-2010, 10:39 PM   #10
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Great info, now I need to find one of those little Green filter thingys, any ideas folks?
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
