Old 09-23-2008, 11:13 PM   #1
greystoke
Power locks?
How many of you have put in power door locks? Whose setup did you use and how difficult was it? any major mods required?
Dano
greystoke is offline   Reply With Quote
Old 09-23-2008, 11:32 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: Power locks?
I've got them. Not a hard install. drill 2 holes behind the panel where they can't be seen, bend the rod a little bit, run the wires and you're done. You will probably have to take your door off to drill the holes. Mine were form Auotloc and part of the security system. They work great.
low'n slow is offline   Reply With Quote
Old 09-23-2008, 11:35 PM   #3
danman987123
danman987123's Avatar
Re: Power locks?
ya i got them too from lmc truck.....2 remotes 2 power lock actuators and the control box for the keyless entry......real nic it was 90bucks for everything like they said up there.....2 little holes to mount the actuator connect the rod...and your done...i never took off my door.....pretty simple and not very time consuming either....
danman987123 is offline   Reply With Quote
Old 09-24-2008, 08:54 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Power locks?
Any pics of what the wires going through the door look like?
68gmsee is offline   Reply With Quote
Old 09-25-2008, 12:27 AM   #5
low'n slow
low'n slow's Avatar
Re: Power locks?
I don't have a better one on this computer. I pulled these looms from a Saturn. There is enough room for my future power window wires
Old 10-01-2008, 07:04 AM   #6
tommypic
tommypic's Avatar
Re: Power locks?
do these bolt on the door and cowl ? I was looking at some that slide in and out of a hole thatwas drilled in both , like this
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 10-01-2008, 08:12 AM   #7
haysonj
haysonj's Avatar
Re: Power locks?
No wires just contacts. Bad thing is you can't roll the window down when the door is open.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 10-01-2008, 09:37 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Power locks?
Thanks for pics, low'n slow. Looks good and good idea using the Saturn loom. I think I'll go for it.
The contacts and slides are other options I hadn't thought about.
