Anyone have a connection for drilled front rotors?
Now Im looking for aftermarket front rotors that are cross drilled. Anyone have a connection?
I wasnt sure if I should be careful where to buy in case the bearings and spline didnt fit correctly. 72 fronts, 2wd
Blazer Project Last edited by gottwake; 09-23-2008 at 11:18 PM. Reason: forgot something |
![]() Join Date: Oct 2005
Re: Anyone have a connection for drilled front rotors?
I actually got mine through NAPA a couple years ago....drilled and slotted.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
NAPA...really? Thanks
Blazer Project |
#5 | |
3DrDwn--the 'burb not the band
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
Surviving, one day at a time!
Mine are the Baer Decellarotor they are drilled and slotted. Summit has the Powerstop rotors that are just drilled. P/N AR-8600L and AR-8600R $79.95 ea.
Heres mine: ![]()
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver 74 swb,350,350,driver & future project "There's no such thing as a finished project" Last edited by GMBowtie79; 09-25-2008 at 12:43 PM. |
Be careful getting a drilled rotor, I would go slotted, drilled rotors crack!
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride Last edited by jkaylor68gmc; 09-25-2008 at 12:46 PM. |
![]() Join Date: Aug 2005
Meh, only if you're running the 24hr Lemans and the holes are not camfered. For street use they are fine. Most people want them for the bling anyway and realize that's all they are.
One day...
Yea that is cool i didnt know Napa sold them either.
Dude...It's all about the bling.
Blazer Project |
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada ![]() MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm MMA RECORD 24-5 |
#13 | |
#14 |
Just searched again and found a new product they are carrying. Here are the search results. The bottom ones are the new product. The top two are what I linked earlier. Linky
