Old 09-24-2008, 09:19 AM   #1
drmiller1
Dash Illumination & Blinks
Hello Guys, I am wondering about my dash light bulbs, specifically the turn signal bulbs. My turn signals work on the corners,but I get zip on the dash indicators.
After poking around some I discovered one wired socket with a 194 bulb in it, just dangeling under the dash. Looking at the back of the the instrument panel
I noticed just the plastic bulb sockets w/194 bulbs in the places where the blinker lights go. Is this right? Thanks.
1969 C10
Nothing better than an old truck...
76 C-10 Silverado
92 Silverado Z71
drmiller1 is offline   Reply With Quote
Old 09-24-2008, 09:32 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Dash Illumination & Blinks
Yes,the lights just twist in. The plastic curcuit sheet makes the electrical connections.
sneakysnake is offline   Reply With Quote
Old 09-24-2008, 09:50 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
You may have a loose ground or a fuse that is not getting good contact.
I had the same problem on the way home last night.
I cleaned the corrosion off a fuse and made sure the ground was ok, so now it works.
Everyone of my trucks had a bulb dangling under the dash when I got them, they were either for the glove box or the heater control.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-24-2008, 10:36 AM   #4
drmiller1
This bulb looks like the other dash ones( which are grey) except for the wire.
Should all of the dash bulbs be the same? thanks
76 C-10 Silverado
92 Silverado Z71
Old 09-24-2008, 11:06 AM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
I believe that the wire is like a fiber optic cable and the other end likes up your shift indicator...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 09-24-2008, 02:33 PM   #6
sneakysnake
Yes, that is your shift indicator fiber optic. It uses the light off that bulb to light up the needle
Old 09-24-2008, 04:45 PM   #7
drmiller1
Does it matter which socket it is in? Thanks
76 C-10 Silverado
92 Silverado Z71
Old 09-25-2008, 08:46 AM   #8
sneakysnake
Be sure not to put it in any of the designated sockets, like blinker,alt,brake,hi beam light holes.
Old 09-25-2008, 11:08 AM   #9
drmiller1
Thanks Sneakysnake, Your help was greatly appreciated and spot on!
76 C-10 Silverado
92 Silverado Z71
Old 09-25-2008, 01:47 PM   #10
sneakysnake
Welcome
