front swaybar stands
I'm about to install my front swaybar (1-1/4"
Tot Roddin'
Re: front swaybar stands
You can actually install a sway bar without using sway bar brackets, but I think it will depend on how low your truck is. If it's at stock height, then I would use the standard bracket, otherwise lowered brackets/no brackets, would probably put your suspension in a bind.
Since your truck is lowered, I think you would be okay to bolt them directly to the frame and not worry about the brackets. It will pull the bar that much more off the ground... and clearance is a good thing! ![]() Good luck with the install!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 09-24-2008 at 03:03 PM. |
![]() Join Date: Oct 2001
I got 2 1/2 drop spindles on our project and I got all the sway bar brackets, should I use the stands also w stock height springs? I do need one of those
1 1/4 bars though seeing I dont have a swaybar itself!! thanks guys
Things happen for a reason! |
I got the kit from ece brackets , bushings ,bolts everything except the bar . I got that at junk yard for about ten bucks . complete set was about 64.00.Truck is 68 gmc everything on the truck is stock i used the lowered brackets.Every thing worked great about an hour to install.
#5 | |
Mild drop (2-4") = shorter aftermarket stands. Extreme drop (6+") bolt it directly to the frame. Each one of these scenarios should keep the bar level w/the frame @ ride height.
Out of the carpool lane.
IIRC for a mild drop you can flip the bar upside-down and bolt it to the frame. I seem to recall having done this on my '67 many years ago.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
![]() Join Date: Jul 2005
Here is a process created by a board member with pictures. Found in FAQ
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
I've seen guys install the bar on the inside of original brackets on mild drops vs. purchasing new shorter brackets.
#9 | |
Tot Roddin'
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Long Fleet Club
That is right if the drop is with coils. Drop spindles should have the sway bar mount at the stock location right?
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
4" drops would be spindles & springs (or bags) & would be where I would start considering the use of the shorter stands (or reversing the mounting position using the stock stands).
