Alright Alright Alright
finding TDC without heads or cam
i have a 350 short block that im trying to assemble. im about to install the cam shaft and heads, but how do i know if its at top dead center? i know that the no 1 and no 6 pistons will be at TDC, but is the compression stroke or the top of the exhaust stroke? what position should the sproket dots be lined up at? the 12 or 6 clock positions?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
I'm a poor spectator
Re: finding TDC without heads or cam
When you put the cam in the crank dot will be facing straight up and the cam dot straight down.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Size Matters
Jtrux beat me to it but here you go anyway.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() Last edited by Longhorn321; 09-24-2008 at 04:34 PM. |
Active Member
![]() Join Date: Jul 2007
If those two dimples are lined up as shown, it really doesn't matter about TDC for now.
It's when you put the distributor in that you have to indure it's set up properly. |
before trying to go any further let me suggestr a trip to the autoparts store and getting a book om rebuilding the smallblock chevy engine you might also try at a local library //they're real cheap compared to the price of replacing parts damaged due to lack of knowledge
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 09-24-2008 at 06:52 PM. |
Just so you know: When the dots are lined-up as in the above picture, that is the compression stroke for cylinder #6. So to simplify matters, just stab the distributor pointed toward #6 rather than the traditional #1.
#7 | |
Size Matters
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
Just so you know. There's no such thing as a the compression stroke till the cam is there. They are telling you right, line the 2 dots up the way the pics show. Once you finish adjusting all the valves and put the intake on, spin the motor manually with your finger over the #1 spark plug hole. When it blows at you you are on the compression stroke. Bring the motor up to 10 degrees before tdc and line the rotor up with the #1 plug wire terminal. This is the way I do it and I almost never have to mess with the timing to get it to fire up. You'll still have to adjust the timing with a light after it's running. It's just meant to get it close enough to fire up easily. It put's about 10 degrees of initial advance in the distributor.
By the way it's always very good practice with a new motor to check TDC on your motor before putting on the heads for the first time. Then you can verify the accuracy of your timing pointer. You would do this with a dial indicator. If you position the dial indicator over the piston. Basically you want to bring the piston up as high as it comes up on the normal rotation and make note of what the pointer shows. Then rotate the motor the other way and do the same. The true TDC is between the 2 readings from each rotation. You can also accomplish the same thing with a piston stop, which is probably even easier. You rotate it each way till it contacts the piston lightly and the middle is still TDC. You'd be surprised how often people have mixed up pointers with the wrong diameter balancers and had the timing off in left field. I ended up writing a novel here, but the advise they gave you about getting a book to reference is great advice. I've built a lot of motors, but still reference a book for stock type torque specs when I need them.
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
