Airline routing out of front crossmember!!
I am running my airline out of my front crossmember and I dont really know where to drill a hole at to run it through. I have a 4 inch Z with plates on the top. If anyone could help it is very appreciated.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
Re: Airline routing out of front crossmember!!
Come on guys. I know most of you have already done this.
I just opened up a smaller pre-existing hole on the pass side of the notched factory style c.member in the truck.
The hole faced the rear of the truck. The drivers side airline was routed through the center of the c.member to keep it out of harms way & exited w/the pass side airline. To protect the airline where it passed through, I slid a piece of rubber hose over the lines & pushed it through the hole until it was centered. I then threaded some stainless nuts down over each end to keep the hose from popping out (cheap & I already had the hardware from another installation).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-24-2008 at 10:22 PM. |
3DrDwn--the 'burb not the band
I generally do something similar to Scoti and drill a hole in the upper spring pocket faceing the rear of the truck I found some cool grommets that fit snugly around 1/2" DOT line and take just a slightly larger hole to be drilled. Then I secure the line to the frame on the outside as I run it back to the valves.
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
soon to be bagged64sub
Yup me too.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
Thanks a lot. I know someone had some ideas
That's what I did too.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
![]() Join Date: Feb 2008
Sorry for the quality of the pictures. This is what I did. Went to fastenal and purchase some bulkhead fittings. This away there were no rubbing issues at all. They come in a variety of sizes and are easy to install and use.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
#9 | |
One day...
Very cool idea
Are those a DOT type fitting?
#13 |
the bulkhead connectors are a neat idea, but keep in mind the more connection an airline has the more places there are for leaks.
#14 |
I agree..... especially in 'hard to access' areas. It makes it that much more difficult to trace possible leaks. Bulkhead fittings do make for a clean install for the cost though.
#15 |
Scotti,
I do not know if these fittings are DOT approved. I do know I use them all the time on our dump trucks and tractors and have never had a failure with them in 7 years. That is a good question though. I do know that my tubing is DOT approved. From my experience if you have the tubing cut square it minimizes your chances of having leaks. I will have to do some research down and see if I can find the answer to your question. Thanks
#16 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-28-2008 at 04:07 PM. |
#17 |
Resistance is Futile
I just went thru this same problem and ended up using 1" male PVC connectors w/ lock nuts. They are made for electrical conduits and if you can put wire thru it should work w/ the line (my thinking anyway). They are smooth and open on the inside......drilled my holes so there was just a slight curve to the 90* fitting on the bag for the line to make. It was easy to hook up as the line will slide thru no problem.... cost about 2 bucks.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
