Old 11-19-2002, 05:28 PM   #1
Shane
Shane's Avatar
Question about I-6 engine towers...
I know the I-6 engine towers mount in the back 2 holes on the chassis...hence the engine sitting further back. But do they mount the engine "lower" in the frame? (closer to the crossmember)
Thanks...
Shane is offline   Reply With Quote
Old 11-19-2002, 05:59 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Shane, I am not 100 percent sure. What I can tell you is the stands are very similiar in height. I just can't remember how the 6 sits on them compared to the 8. Sorry, not much help. I have my 8 (or will have...it was previously) sitting on the 6 stands in the back position.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-19-2002, 06:29 PM   #3
crazy longhorn
Fabricate till you "puke"
Shane, if there is any difference.....it cant be more than about 1/4". I tryed to get a measure 1 time, & as far as i can see the crank centerline is on about a 4 degree angle, so the height will change a little by moving the engine, but not very much in that 3 1/2" of setback. My longhorn is on 6 /250 stands,& i run the long waterpump,& havent had issues with centering the fan in the rad shroud.......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
