Please:::::::> What Kind Of Valve Is This?
The PO installed this valve in the water line running from the radiator to heater.
Fixing the system is a project for down the road... right now the valve is corroded and stuck open and I need to replace it. But what the heck is it called & what size do you think it is? ![]() |
![]() Join Date: Sep 2005
Re: Please:::::::> What Kind Of Valve Is This?
on and off vavle for the heater core so come summer time you can cut coolant flow to the heater cores it is nto factory just find a new one
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
its all about the +6 inches
while it isn't stock, it IS taking the place of a stock one.
The photo shows an A/C truck, and right there is supposed to be a valve that is controlled by engine vac, that shuts off coolant flow when the A/C is kicked on. |
I was wondering what the valved is called. I want to buy one but don't know where to start.
I looked it up in one parts magizine and they simply called it a heater valve.
72 Cheyenne Super 80 Silverado Blazer 2wd |
you can fix that valve. Unscrew the part on top just under the handle. Pull the guts out, clean it up a little, replace the orings or gaskets, and you should be good to go.
go cyclones
That's either a 5/8" or 3/4" ID hose. Just take it off and go to your local harware store. You should be able to find a brass or black iron one for around $5-10.
I am a Referee of life.
Get bras, it wont corrode so much.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
