09-25-2008, 01:40 AM | #1 |
Stepside Fanatic!
How do I make my truck ride like a Cadillac?
Instead of shake-shake, bounce bounce, rattle...I'd like it driving smooooother! Maybe new motor & trans mounts? Any ideas? Thanks!
09-25-2008, 03:19 AM | #2 |
Re: How do I make my truck ride like a Cadillac?
That's a start. I'm no expert but I would imagine that in combination with dynomatting the cab and replacing all the bushings would help out quite a bit.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
09-25-2008, 03:23 AM | #3 |
insulate the cab a ton and put air ride all the way around! or just buy a cadillac
09-25-2008, 05:20 AM | #4 |
KEEP ON TRUCKIN'
By a cadillac and take the trunk lid off.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
09-25-2008, 09:11 AM | #5 |
great southern land
exactly wat i was gona say
rod 86 chevy c10 silverado |
09-25-2008, 10:12 AM | #6 |
+1 for the other posts.
replace cab bushings insulate the cab bag it this will help but it will never be a caddy |
09-25-2008, 10:49 AM | #7 |
Happy to be here
Tell us more about your truck. Lets start with the tires and work up. What size tires are you running? Tires that are too short, to stiff, or too heavy can have a huge impact on your ride. What about shocks? How long has it been since they were replaced, and are they the right shock for your application? Too soft can be just as bad as too stiff.
We can keep going from there, but we need more details.
09-25-2008, 01:09 PM | #8 |
Arrived on a Pale Horse
buy an Escalade EXT
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
09-25-2008, 02:09 PM | #9 |
Put a heavy load in the back. Seriously.
I've had two LWB trucks, and they both rode super smooth like a Caddy with the rear loaded down. Once I even hauled a spare bench seat at the very rear of the bed, and the back of the seat stuck up like a spoiler and gave some serious down force (probably drag too ). I could weave in and out of traffic like the rear end was glued to the road. The problem is that the springs are meant to maintain an acceptable ride stiffness and ride height at the maximum load rating. When unloaded, you have way more spring rate in the rear than you really need so the rear tends to be a little jumpy rather than calm like a Caddy. The best solution is helper air bags. You remove leaf springs to decrease the spring rate, then the helper air bag pressure can be adjust to support a heavy load, or to provide less spring rate for running unloaded.
1977 GMC Sierra Grande |
09-25-2008, 04:34 PM | #10 | |
I was actually picturing that happening as I was reading it. LOL!!!
09-25-2008, 04:45 PM | #11 |
Size Matters
I would also add that the wheels will have a huge impact. I personally am not a fan of aftermarket wheels for this very reason. I have worked on a lot of vehicles with the wheels and they usually rode like sh!%$. If you stick with the stock wheel/tire combo, you should be able to get a fairly smooth ride (for a truck..),assuming the shocks/suspension are OK as mentioned above.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
09-25-2008, 06:45 PM | #12 |
>130dB Moderator
Also, going with a tire that is more narrow will improve ride quality.
The biggest things that is going to affect your ride are the spring rate, shock, and most of all, the tires. Bushings and the rubber bits aren't going to effect it THAT much when you compare it to the three items listed above. Also, worn out seats can sloppy steering can play a significant role. Basically, there's ALOT of things that effect the ride quality of your truck, you just have to go through systematically and take care of each one until you are happy.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
09-25-2008, 09:23 PM | #13 | |
Happy to be here
It's true that a larger wheel may have an effect due to added unspung weight, but it's a misconception that wheel that is bigger than stock is the problem. The low profile stiff sidewall performance tires are usually the culprit.
09-25-2008, 09:33 PM | #14 |
I have had several lowered chevys and the best riding one had poly lift air bags inside the front coils. I put just enough air in the bags to fill the spring. That truck rode like a Caddy. I put together two other trucks with the same set up but didnt install the air bags and they didnt ride as nice.
09-26-2008, 10:11 PM | #15 |
Velvet ride shackles???
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
09-26-2008, 10:57 PM | #16 | |
Size Matters
BTW..Not bagging on N2TRUX opinion...I'v just seen a lot of rides where the owner got what he paid for.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! Last edited by Longhorn321; 09-26-2008 at 11:03 PM. |
09-27-2008, 09:09 AM | #17 | |
To make mine more cushy I am planning on replacing the rear suspension with the early style rear trailing arms,and get rid of the leaf springs. I also plan on using 6cyl/sbc 1/2t front coils and bilstein shocks,polyeurethane bushings through out the entire truck. Good Luck -Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
10-20-2008, 09:02 AM | #18 |
I have a 77 half ton stepside, but it was factory ordered with an 8 leaf spring pack in the rear :O i got rid of about 60% of that problem by taking the rear leaf springs off and took them in to a local spring shop. they took out i believe the third and fifth leaf, and the bottom super thick one they flipped over so its inverted. this lowered the rear by about 2 inches and made a HUGE difference in ride quality. hope it helps
