Old 09-25-2008, 10:31 AM   #1
thefatguy
1983 Tilt Steering Column to 1978 Big 10?
I've found a tilt-steering column for my 1978 Big 10. It came out of a 1982 C-10. Does anyone know if that's a straight drop-in type of deal?
I've never done a steering column before, so I'm kind of nervous about messing with something that seems important like steering. Am I biting off more than I should? Yes, I'm a big old wuss.
1978 Silverado Big 10 - "The River Runner"
1969 GMC C/10 - "The 2008-09 Winter Project"
thefatguy is offline   Reply With Quote
Old 09-25-2008, 05:18 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 1983 Tilt Steering Column to 1978 Big 10?
i dont think it will work.. the 83 has wipers in the turn signal and the hole is different.. if its an 82 ( it says 83 in title 82 in thread) it should work... you may need the lower shaft tho to make it work,,, hope that helps
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 09-25-2008, 05:22 PM   #3
Red_69
Red_69's Avatar
I think wipers were in the dash until 1985.
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 09-25-2008, 05:23 PM   #4
thefatguy
Yeah, I screwed up my post -- the guy says it's an 82. I'm checking with him about the wiper controls.
Old 09-25-2008, 07:16 PM   #5
ChaseDale3and8
ChaseDale3and8's Avatar
It will interchange as long as it's an '83 on back. 1984 was the year that the wiper switch was moved to the turn signal stalk. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 09-25-2008, 09:17 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by ChaseDale3and8 View Post
It will interchange as long as it's an '83 on back....
Not exactly. There were some changes in connector plugs and shaft shape along the way. It can be made to work, but it might not be a straight across swap.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-26-2008, 12:55 AM   #7
flamingbig10
6.0 powered square
flamingbig10's Avatar
my buddy has a 78 big 10 and he did the swap with a 84colum bolted up just fine, just keep using the dash mounted wiper switch.
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-26-2008, 05:18 AM   #8
S10Fan
Old Heap Driver
I used an 85 Blazer column in my 80. I wired up the column wiper switch (and a delay module) to my existing wiring. The dash switch is still there and I'll use that spot for something later on. I also had to mess with the ignition switch, I just can't remember what the issue was.
My truck is a manual tranny, so I still need to eliminate the remains of the column (automatic) shifter.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 09-26-2008, 09:32 AM   #9
thefatguy
Well, the guy says no wiper controls on this column, but I'm gonna take a pass, as I really have more important mods to do.
Thanks for all the help, folks...much appreciated.
