Old 09-25-2008, 12:53 PM   #1
72-c20
Packrat
72-c20's Avatar
picked up a couple of tachs at a swap meet...
Gave $30 for the pair....
now to see how well they can be fit into the cluster...
both are 3 3/8" diameter.
I found camaro clusters, but the tachs were larger....
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 09-25-2008, 01:49 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: picked up a couple of tachs at a swap meet...
I think there is a how to in the FAQ on after market tach installs...
LockDoc
Leon
Old 09-25-2008, 01:53 PM   #3
72-c20
Packrat
72-c20's Avatar
yeah. I think the autometer one should work just fine. the sunTune one however is pretty large (backside) so I'm not sure if it would fit with the printed circut sheet.... I have a test cluster to work with too from Wrench n' Go
Old 09-25-2008, 06:53 PM   #4
I have a Suntune in my tach hole.The rim sits outside the bezel.
Old 09-25-2008, 07:02 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
I like the old school look of the SunTune...
Old 09-25-2008, 07:37 PM   #6
bowtieboy93
bowtieboy93's Avatar
the autometer wont work with a msd box
i have the same one and mine wont for some reason......
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 09-25-2008, 10:58 PM   #7
Husker
Husker's Avatar
If that is permanent marker on there take a Dry Erase marker and scribble over it good and it will take it off.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 09-26-2008, 12:41 PM   #8
72-c20
Packrat
72-c20's Avatar
do you have a pic of the cluster?
Old 09-26-2008, 02:39 PM   #9
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
^plus 1
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-03-2008, 11:01 AM   #10
72-c20
Packrat
72-c20's Avatar
this is how I ended up doing mine. it's a near perfect fit sliding in...
I swapped out the ammeter with a volt meter from a mid 70's chevy, and I added the analog clock from the same chevy truck in place of the small blank hole on the right....
all mods/cuts were fitted on my spare cluster, now I just need to swap all the modded pieces and gauges into the '72 cluster....
Old 10-03-2008, 11:06 AM   #11
Jerry Jones
Happy Camper
Jerry Jones's Avatar
You taking pics of progress?
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 10-03-2008, 11:15 AM   #12
72-c20
Packrat
72-c20's Avatar
I'll get pics of all when I actually put them into the 72 cluster....
for the Suntune tach, I cut the main rear plate big enough to let it slide through, but it didn't reach that far. probably only needed about a quarter size hole.
Old 10-03-2008, 11:21 AM   #13
72-c20
Packrat
72-c20's Avatar
and whatever the lense is made out of, it gives off some noxious fumes when melting.... I cut out the original "blank" lense area, which ended up with the whole lense plate in 2 pieces, but worked out good....
I tried a scroll saw to help trim out the lense area, it cut really well, but ended up actually melting the plastic, and as I kept cutting, the cut "welded" itself back together a wider blade might have helped... ended up just using a dremel to finish what it had started.....
Old 10-03-2008, 02:35 PM   #14
Jerry Jones
Happy Camper
Here is mine. (Un)fortunatly it was done when I bought the truck, so I dont have details on the how to.
Old 10-03-2008, 03:12 PM   #15
Shane
Shane's Avatar
Those short-throw Sun tachs are so cool.
Shane is offline   Reply With Quote
Old 10-03-2008, 07:12 PM   #16
Sport/Truck
Sierra Grande Club
Do you know how to get one? They still make'em?
s/t
Old 10-03-2008, 07:22 PM   #17
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Jerry that is a cool set-up you have there..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-05-2008, 07:39 PM   #18
72-c20
Packrat
72-c20's Avatar
Ok. got some pics with my test cluster....
Detail pics here....
http://www.indysworld.com/vehicles/67-72-dash/
Old 10-05-2008, 07:53 PM   #19
Cyclone44
Step Brother
Cyclone44's Avatar
That looks good....
Cyclone44 is offline   Reply With Quote
