Old 09-25-2008, 03:19 PM   #1
spudz
spudz's Avatar
Rebuilding Q-jet carbs.....any good books???
I am wanting to rebuild the q-jet in my 79...is there any good books or online refrenses I can check out??? I don't simply want to tear it apart and put it back together.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 09-25-2008, 03:50 PM   #2
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
Re: Rebuilding Q-jet carbs.....any good books???
Funny you ask..
Cliff Ruggles is a guru with Qjets, I have this book and I have learned a bunch from it, and I was able to rebuild and modify them before I got it. Now I make them run better and I have a reference as to what parts I need and where to get them.
Its not how to put a gasket kit in, its how to rebuild them, that includes throttle shaft bushings (easy to do) main jet well plugs (even easier to do), and tuning it for power, economy, and drivability.
You can get it from a number of places. I ordered it direct from him in Ohio, and got some throttle shaft bushings at the same time. Now I need ethanol friendly accelerator pump diaphragms, since they dont come in any of the kits.
Cliff's website
There are a couple other books out there, and if you want I can find the links. This one has a bit more info in it than one of them, and is on par with the other one.
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 09-25-2008, 04:12 PM   #3
spudz
spudz's Avatar
Originally Posted by Thumpin455 View Post
Funny you ask..
Cliff's website
I ordered one titled "How to Rebuild and Modify Rochester Quadrajet" I think it will get me started...I will check out his site too ...thanks!
Old 09-25-2008, 04:14 PM   #4
spudz
spudz's Avatar
Awesome seems the book I ordered is the same one you are talking about!... Also is there a electronic choke conversion??
Old 09-25-2008, 04:30 PM   #5
Thumpin455
Thumpin455's Avatar
I swap the electric chokes over from carbs that have them to carbs that dont. Not that difficult to do provided they have the right bosses and throttle shaft pieces.
Old 09-25-2008, 04:49 PM   #6
spudz
spudz's Avatar
Can you explain to me how this choke works?? I dont see any heat tubes or anything.... this is the carb I am going to be rebuilding and the intake I am going to use after its blasted. its a edelbrock spread bore intake and the carb that came on my truck...
Old 09-26-2008, 04:45 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
There's an article in the new Rod N Custom that lists the brand and part numbers for kits with the ethanol friendly (Viton?) accelerator pumps for most carbs, including quadrajets.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-26-2008, 05:12 PM   #8
COMP
Slonaker
need to pick one up at the store
COMP is offline   Reply With Quote
