Old 09-25-2008, 08:57 PM   #1
matt_field
matt_field's Avatar
master cylinder sprays fluid without cap on?
i was trying to bleed the brakes out on my 87 1 ton, i had the cap off the master cylinder and when i hit the brakes it sprays fluid like 5 feet in the air of brake fluid out of the rear resivoir. any idea what that is? do i have a bad master? thanks!
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 09-25-2008, 09:02 PM   #2
79GMC_OLDS
79GMC_OLDS's Avatar
Re: master cylinder sprays fluid without cap on?
thats normal
79 GMC Sierra 5.9 cummins, nv4500
79GMC_OLDS is offline   Reply With Quote
Old 09-25-2008, 09:21 PM   #3
impalamark
impalamark's Avatar
Just loosen the cap and watch the level
they can spray and make a mess
impalamark is offline   Reply With Quote
Old 09-25-2008, 09:23 PM   #4
454HO
Don't 'hit' the brakes, just push the pedal s-l-o-w-l-y. If you are pumping fast then any air in the line will turn to foam making it even that much harder to get out.
- Greg
454HO is offline   Reply With Quote
Old 09-26-2008, 01:24 AM   #5
Allens86
Allens86's Avatar
yea probably cuz you pushed down the brake pedal too fast while you were bleeding it but yea like everyone else was saying its normal just to push the brake pedal slow. I just had to go through that when i put my new master cylinder in.
-Allen
Allens86 is offline   Reply With Quote
