Old 09-25-2008, 10:28 PM   #1
bigdon-70blazer
Mirror help
Has anyone replaced the mirror in the old original mirror Guidex frame? I would like to keep my original one but the mirror glass is deteriorating, the rest of the setup is good. Anybody?
bigdon-70blazer is offline   Reply With Quote
Old 09-26-2008, 09:16 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Mirror help
Interested in this also as mine is pretty bad too.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-26-2008, 10:50 PM   #3
bigdon-70blazer
Re: Mirror help
Has anybody ever done this?
Old 09-26-2008, 11:32 PM   #4
HuggerCST
HuggerCST's Avatar
Re: Mirror help
Are you referring to the rear view mirror?
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 09-27-2008, 07:13 AM   #5
bigdon-70blazer
Re: Mirror help
Yes....
Old 09-27-2008, 09:26 AM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Mirror help
I carefully pried the chrome lip up and removed the old mirror.
Bought a cheap replacement mirror at the parts store and ripped the mirror out of the one.
I outlined the old mirrors profile on the new mirror and a used diamond bit in my Dremel tool to shape it.
It worked out well.I did slip with the Dremel a couple times and have a couple scratches on one of the corners but it's out of my line-of-site and doesn't interfere with the dimming function.
Just take your time when prying up the lip.
A plastic prying tool would prob be the more appropriate tool for this job.(I used a small screwdriver)
I'll get pic's.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-27-2008, 09:53 AM   #7
BobbyK
BobbyK's Avatar
Re: Mirror help
Here's the front side of the old mirror.
You can see the blue towel showing through underneath.
The back.
Most of the silver coating is gone..
The new mirror in the old orig. housing.
Sorry,I didn't take pic's while I was actually doing this.
The rubber ring is easy to get off.The chrome is just a shell with the tilting mechanism in it.
You can see the scratches on the left side of the mirror.
Hope that help a bit.
Old 09-27-2008, 11:24 AM   #8
HuggerCST
HuggerCST's Avatar
Re: Mirror help
I did the same thing with a couple of old map light style mirrors. These mirrors are longer than truck mirrors, but I found that 80's big caddys have the same size mirrors, so I went to the boneyard and picked up a couple of them and swapped out the glass.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 09-27-2008, 04:59 PM   #9
jamie72
jamie72's Avatar
Re: Mirror help
i`m going to install a newer mirror out of an impala there the one with the 2 reading lights mounted underneith.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-28-2008, 08:21 AM   #10
bigdon-70blazer
Re: Mirror help
BobbK, it helped a lot. When you peeled back the tan rubber piece enough to get to the edge of the mirror, was the mirror glued on?
Old 09-28-2008, 12:08 PM   #11
BobbyK
BobbyK's Avatar
Re: Mirror help
I believe it's only crimped in there.I don't remember any type of sealant or glue.
I did this when I 1st got the Blazer,8yrs ago now,so I'm a little foggy on the details.
