Old 09-26-2008, 12:55 AM   #1
baggedcten
86 C10
baggedcten's Avatar
Question fuel cells?
What would be better plastic or aluminum?
I just need something to get rid of original tank inside bed.
I'm leaning towards the plastic since its more in my budget just wanted to see if it would be good enough?
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 09-26-2008, 01:20 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: fuel cells?
I would stick it out and get a stainless or aluminum one.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-26-2008, 01:27 AM   #3
draggin86
draggin86's Avatar
Re: fuel cells?
i just got a plastic it looks great!!! since you're on a budget you mine as well!
draggin86 is offline   Reply With Quote
Old 09-26-2008, 03:32 AM   #4
Baresteel10
Baresteel10's Avatar
Re: fuel cells?
X2 but of course its still your choice.
Baresteel10 is offline   Reply With Quote
Old 09-26-2008, 08:51 AM   #5
Alex1
Alex1's Avatar
Re: fuel cells?
Summit sells some nice aluminum ones and they are not too expensive. Plus you can get them natural or in a couple of different colors -you could always polish one if you wanted to go fancy. My vote is for an aluminum one!
Alex1 is offline   Reply With Quote
Old 09-26-2008, 10:42 AM   #6
oldgmc
oldgmc's Avatar
Re: fuel cells?
I am also planning on a fuel cell in my 79 k35. Plastic or aluminum will work for me but have a slightly different question.
Is there any problem with state inspections for fuel cells. I am in New Jersey and them do emission inspections before I install a fuel cell just wondering if anyone had any problems with inspections
Thanks Ed
oldgmc is offline   Reply With Quote
Old 09-28-2008, 10:43 PM   #7
baggedcten
86 C10
baggedcten's Avatar
Re: fuel cells?
so there is really nothing bad about the plastic but it will be better if i get an aluminum one right
1986 C10
Old 09-28-2008, 11:17 PM   #8
Hazieview
Building Dreams out of Dimes!
Re: fuel cells?
I too have the same questions about the fuels cells. Any recomendations on what size would fit best for a shortbed?
Hazieview is offline   Reply With Quote
Old 09-29-2008, 01:35 AM   #9
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: fuel cells?
May I suggest that you contact Transfer Flow, Inc. in Chico, CA. They make outstanding fuel tanks. My Big 10 came with one factory 16.5 gallon saddle tank. With a 454, that didn't get me very far before I was riding on fumes. I opted for a 26.5 gallon tank that uses the factory fill and sits between the frame in place of the spare tire. That has been a blessing!
78 Big10 454 is offline   Reply With Quote
Old 09-29-2008, 08:04 AM   #10
bigblock73
yeller
bigblock73's Avatar
Re: fuel cells?
I am running a 16 gallon 'cell underneath my bed...same size tank as the stock one the truck came with.
http://www.73-87.com/7387garage/chas...ellinstall.htm
If I could do it all over again, and money was no object, I might use an aluminum one. But to be honest, since this 'cell is underneath the bed, I am very happy with it and don't plan to change it out.
The problem with plastic fuel cells is they need to be mounted so they are not exposed to direct sunlight/heat. If hey are simply bolted to the top of the bed, they will warp and look like crap over time.
bigblock73 is offline   Reply With Quote
Old 09-29-2008, 01:21 PM   #11
fun in dirt
fun in dirt's Avatar
Re: fuel cells?
Go for the aluminum!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 09-29-2008, 01:31 PM   #12
muscletrucks
muscletrucks's Avatar
Re: fuel cells?
I would be worried that the plastic would warp because to the expanding and contracting of gas.
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 09-29-2008, 02:03 PM   #13
baggedcten
86 C10
baggedcten's Avatar
Re: fuel cells?
so what about this one
heres summits part number-SUM-293220-S
I think its good for the price but what do y'all think about it?
1986 C10
Old 09-29-2008, 03:18 PM   #14
bigblock73
yeller
bigblock73's Avatar
Re: fuel cells?
I don't think that will cause it, it usually the heat and direct exposure to sunlight that causes them to warp.
Old 09-29-2008, 03:21 PM   #15
muscletrucks
Re: fuel cells?
That looks like a good tank. Comes with a 90 ohm sending unit and it is plumbed for AN fittings. With the dimensions being only 24" x 20", there will probably be no frame mods necessary.
1943 Farmall M
Old 09-29-2008, 03:24 PM   #16
muscletrucks
Re: fuel cells?
Here in the great state of Kansas, a law was passed sometime ago banning the filling of plastic gas cans at the gas stations. Is that censorship? HAHA
1943 Farmall M
