Old 09-26-2008, 04:24 PM   #1
Hawker7
Transmission Crossmember
Anyone have trouble removing their trans crossmember? I was able to get the bottom bolts out, but it seems the cab has to be raised to remove the top ones as their isn't enough clearance to pull the bolt up and out????
Hawker7 is offline   Reply With Quote
Old 09-26-2008, 06:16 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Transmission Crossmember
I had to cut the bolts and install new ones from the bottom up. GM wasn't thinking very well when they did that.
Old 09-26-2008, 07:35 PM   #3
kwmech
I never have a problem when the body mounts are good. Put 'em back the same way
Old 09-26-2008, 08:40 PM   #4
70 net440
Junior Member
70 net440's Avatar
If the bolts are the stock length, you should be able to use a pry bar or a crowfoot bar to raise the floor up enough to get the bolts out.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 09-26-2008, 08:46 PM   #5
Hawker7
Thanks, All good suggestions. I have to say it was one of the first times during the build I thought to myself, "who thought of this?"
