front end and rear end questions
how good is the 10 bolt front end......and is a 14 bolt rear better that the stock eaton that came on my 69 K20 custom camper. Thanks for all the help
1969 Chevy K20 Custom Camper 350, 4sp, 33's High on plans, Low on funds |
its all about the +6 inches
Re: front end and rear end questions
the 14 bolt is just as good, if not better.
the real area it shines in, parts avalibility, and gear ratio avalibility. |
The 10-bolt gets the job done up to a point.That point is serious wheeling that puts most any axle to the test,and that`s with larger tires.They do just fine for normal use.I never hurt the one in my diesel Suburban with 12.50/35s.Mostly mud on job sites or up eroded muddy logging roads.
The Eaton HO52 is a great rear that I`d leave be as long as it`s working fine,which they have no problem doing when serviced properly,like forever.They are just as strong internally as the 14-bolt full-floater.They are alot lighter and less bulky,too.4.10 is the most highway friendly ratio they came in,which is my gear of choice for my trucks.I run 33"+ tires.A 35" tire on a 4.10 will net you right about 3.73:1.Anything taller,in my book,ain`t a hauler as far as I`m concerned. It all depends on use and equipment.My`90 Blazer ran 3.08s,12.50/33s,10-bolt/12-bolt and did great.I had a manual 4spd so I could use granny when towing.3.08s is like having full-time o/d in my book.Just a note:I sold it @193,000 with the original clutch and tall gears are tough on a clutch...not that I toed that much with it.But the bigger tired simulate hauling to a degree.Never hurt that 10-bolt either.
I put the 14 bolt under mine because of parts availability and was told I would have more gear options. wanted to match the 4.09 that was in the Dana 44 front axle. I'm running 35 in tires with a Gear Vendor OD. Good highway cruise with plenty of low end power for towing.
69 Chevy 4x4 383 Power ![]() |
there is nothing wrong with my front (Dana 44) or rear end. I am running 4.10 gears with 33's and the new ones would be the same. I am mostly interested in the front because it has disk brakes and I am in the process of installing hydroboost and would like having disk brakes.
#6 | |
