Old 09-27-2008, 10:32 AM   #1
blazer2007
how do you insulate doors
I was wondering how everyone was insulating the doors for sound and how did you get in there,not much room, is 78 chev
blazer2007 is offline   Reply With Quote
Old 09-27-2008, 10:41 AM   #2
FlatBrokeRacing
FlatBrokeRacing's Avatar
Re: how do you insulate doors
I used a cheap alternative to Dynamat inside my doors. They don't sound like a tin can anymore.
I gutted my doors for another reason and figured, While everything was outta the way.....Why Not.....
FlatBrokeRacing is offline   Reply With Quote
Old 09-27-2008, 10:43 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Before you install you will need to spend some time cleaning the inner side of the door skin. That's almost as easy as giving your cat a bath in a tub full of rubbing alcohol.
We used Brown Bread which is similar to Dyna-mat,etc. Measure the holes that you can get through and cut it in strips. Carefully put it through the holes and attach as evenly as possible.
It helps to add it to the back side of your door panels too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
