Phone's ringin Dude.
![]() Join Date: Mar 2007
Popping sound in control arm
I've been driving my truck a lot lately, and she's developed a quite annoying popping noise in the drivers side lower control arm. It sounds like someone is hitting a vise with a ball peen hammer. I'm headed to nappa to order new control arm shafts, as thats about the only thing that isn't brand-spankin new on my front end. Anybody else have this problem?
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
Dave's not here, man
Re: Popping sound in control arm
Are your springs cut? When I cut mine they used to bounce around in the pocket when I went over bumps too quickly. Just a thought. I also had a pop like you described once and it turned out to be the nuts that hold the shims in place. Hope you get it figured out.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
My springs do have one coil cut off. I was thinking that's what it was, but it takes very little movement to cause it. I'll check the nuts too.
have you checked the u bolts that hold the lower control arm shaft in place? the control arm can shift if the u bolt works loose. not to mention the old u bolt breaking thing.
i survived cancer and kidney stones, but my kids are killing me. |
![]() ![]() Join Date: Jul 2002
Lower ball joint? I have seen and heard a couple where they would pop loose from the press-in fitting area, then pop back into place later
![]() Join Date: Aug 2003
Ball joints will also do this when not enough grease is used.
Lube the front end. Sounds like a dry ball joint? Did that once on a 70 Nova.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
I had that happen once in my camaro. It turned out to be a loose fit where the ball joint pushed into the control arm.
I don't know about these years but on my 85 one ton I replaced the a arm and did not get the spring located in the right spot. drove me crazy until I took it to an alignment shop and they found it.
69 Chevy 4x4 383 Power ![]() |
