Old 09-27-2008, 02:39 PM   #1
Kager67
what knocking sound?
Kager67's Avatar
cruise control
Hi guys. My 78 blazer has c\c, but its not working right. Sitting in the garage, it wil work (most of the time), but get it out on the highway it won't. So I guess my question is does it need to be taken apart and cleaned or is it something else. Thanks.
Kager
1968 C-10
1953 belair two-door post
1955 chevy 3600 big window
1950 studebaker starlite coupe
1968 Impala SS
Kager67 is offline   Reply With Quote
Old 09-27-2008, 03:59 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: cruise control
hOW ARE YOU ABLE TO CHECK IT IN THE GARAGE?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-28-2008, 01:29 AM   #3
Kager67
Kager67's Avatar
Re: cruise control
Engine idling and in park, and press the cruise button. The engine starts accelerating until I hit the brake. I thought that was a bit strange myself, but it did it multiple times.
Kager
1968 C-10
1968 Impala SS
Old 09-28-2008, 01:41 AM   #4
BLE 'BURBAN
Re: cruise control
Sounds like the control module is messed up. Thats the unit mounted to the fender well and you speedo cables hook into it. Your c/c shouldn't actuate unless your at a minimun of 25-30 mph. and never in park or at an idle
Old 09-28-2008, 02:26 AM   #5
Kager67
Kager67's Avatar
Re: cruise control
Would it more likely be a mechanical problem or electrical? Thanks
kager
1968 C-10
1968 Impala SS
Old 09-28-2008, 07:58 AM   #6
BLE 'BURBAN
Re: cruise control
Electrical
Old 10-01-2008, 01:27 AM   #7
78 Chevyrado
Re: cruise control
Mine on my 78 c20 did that exact thing. I hit the button and dang near blew the engine when it revved up quick. also on the road it didn't matter what speed, if you hit the button it just floored the gas. On my truck the transducer was bad. the part on the inner fender with the speedo cables going to it. I bought a Remanned one from rockauto for about $100 and it fixed me all up. Works perfectly now. It is identical in appearance to the original unit.
Look it up in rockauto's catalog under Electrical>curise control transducer. The two terminal unit is for trucks with no cruise indicator light in the dash (like mine). The three terminal unit is for trucks with an indicator light in the dash.
78 Chevyrado is offline   Reply With Quote
Old 10-03-2008, 05:13 PM   #8
Kager67
Kager67's Avatar
Re: cruise control
Thanks, I'll look into that!
1968 C-10
1968 Impala SS
Old 10-04-2008, 10:03 AM   #9
screwballl
Tonawanda 454
screwballl's Avatar
Re: cruise control
mine has never worked in the time I have owned this 91... but it would have been nice to use it a few times...
no transducer on mine
Cruise Control Module
Cruise Control Sensor
Cruise Control Servo
Cruise Control Valve
oh well I am selling it so no need to spend $400 in parts trying to figure out whats wrong...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 10-04-2008, 09:59 PM   #10
BLE 'BURBAN
Re: cruise control
On yours the most common thing to go wrong is the switch it's self built into the turn signal lever. You can replace it very easily by simply disconneting the wire under the dash and pulling straight out on the arm then thread the new wiring down the column and push the new arm into the turn signal switch.
Old 10-05-2008, 10:30 PM   #11
Kager67
Kager67's Avatar
Re: cruise control
FYI......I found out NAPA has them as well for about the same price (plus there's a NAPA three blocks from my house.) Thanks again for the help.
Kager
1968 C-10
1968 Impala SS
