New Member
![]() Join Date: Jun 2006
Shaved Firewall help
I’m in the process of filling some holes in my firewall. I’m deleting the factory heater and will install an under dash hot rod heater. I want a cleaner look for the firewall. I checked the shaved firewall threads and couldn’t find any identifying all the holes. Could someone please id the holes circled. I assume the one to the left of the steering column would be for the clutch. I will be needing that as this will be a standard. I filled the hole for the fusebox as I will be using an aftermarket harness. This is a 68 cab and I will be using the throttle set up from a 71. What holes could I fill?
It would be great to see different ideas and pictures of routing wiring and plumbing to make things more appealing. Thanks in advance. ![]() |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: Shaved Firewall help
Will this help?
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Active Member
I've seen that pic before and it answers bullwinkle's question great...but all you guys and gals with shaved firewalls, send us some pics of where you routed everything to keep that ultra clean look. I'd love to see this info too.
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
New Member
Thanks myoldchevytruck. That is what I was looking for. It will be a big help.
I also agree with kevncar about seeing some pics of rerouted wiring etc for ideas. Thanks. |
the smaller holes you have circled are for the inner firewall board in which the rubber holders come thu
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
Restoration Virgin!
That pic is from a 71-72 cab I believe, but was tremedous help for me....way to go Harry!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Unfortunate for me, I've sent that pic to many people (Think I got it from Ohio Dan) But I have yet to do any work on my own firewall. Isn't that always the case...LOL. When I get mine done, I will post pics. Thanks
Here are some of the picts of mine which I am almost done with,,,,We shaved everything except the hole for the steering column, the hole for the throttle cable, brake master cylinder & the fuse box every other hole is no longer in existence. I ran the a/c lines all the way at the end of the firewall on the right side and with the inner fender on you cant see them. The speedo cable is going thru the floor, emergency cable are also going thru the floor. My assistant wants it all CLEAN nothing goes on the firewall. I am going to add some more picts of how we did it maybe it will help you.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 09-29-2008 at 04:13 PM. |
Albert....That Firewall is looking good. Nice Job
Thanks Harry I got your message the other day I tried calling you back but did not get you.. Give me a call whenever you want, you have to come by my shoop and see the progress the truck is at 75% complete just trying to buckle it up. Here are some picts of how we ran the hoses and what the four holes we left...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 09-29-2008 at 04:12 PM. |
Nice...I'm Jealous. I'll give you a call.
