Old 09-27-2008, 06:04 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Plug requirements for 383 stroker/same as 350?
I'm wondering if a 383 uses the same spark plugs (heat range) as the 350.
I'm also using an HEI too. What gap should I use?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 09-27-2008, 06:21 PM   #2
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Plug requirements for 383 stroker/same as 350?
Spark plug requirements are based on numerous things, but the two most important are compression (compression will determine heat range) and reach. Here is a quick guide that I use and a website that is very useful.
http://www.sparkplugs.com/
Here are the recommendations from edelbrock. I believe the plug seats are flat, so you should use the washers (if they are tapered seats, you don't use the washer...)
Under 9.5 to 1 Compression
Champion ---------- RC12YC / 2071
NGK --------------- FR 4 / 5155 OR BCPR5ES / 6130
Autolite ------------ 3926
Motorcraft --------- AGSFP52
Accel Shorty ------- 0416S
Up to 10.5 to 1 Compression
Champion ----------- RC9YC / 2075
Autolite -------------- 3924
NGK ----------------- FR 5 / 7373 OR BCPR7ES / 3330
Accel Shorty -------- 0414S
11 to 1 Compression
Champion ------------ C63YC / 796
NGK ------------------ R5672A-8 / 7173
12 to 1 Compression
Champion ------------- C61YC / 785
NGK ------------------- R5672A-9 / 7405
"Reach" is where the electrode and grounding strap are placed in the combustion chamber. It is the length of the threaded end of the spark plug.
What kind of heads do you have?
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 09-27-2008, 06:39 PM   #3
Sport/Truck
Sierra Grande Club
Thanks for the info.
I have NGK 7052 / YR5 v-power. I'm not sure where they fit in your compression chart....I'm at about 10:1 compression.
s/t
Old 09-27-2008, 06:50 PM   #4
Arad68
Trucks N Tranzams
Arad68's Avatar
Go to www.sparkplugs.com. At the bottom of the page is a link called sparkplug 411. Go to the bottom of this page and you will find a numbering system for NGK
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 09-27-2008, 11:40 PM   #5
Sport/Truck
Sierra Grande Club
OK, thanks, looks like I'm right in the ball park with the heat range.
What gap should I set these at since I'm using HEI? They come factory set at .039.
s/t
Old 09-28-2008, 12:54 AM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
.039 is good. Larger gap tends to dissipate
or diminish the spark. No more than .045
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 09-28-2008, 10:28 AM   #7
Sport/Truck
Sierra Grande Club
Thanks Don....I'll get these put in today!
s/t
Old 09-28-2008, 10:28 AM   #8
Sport/Truck
Sierra Grande Club
s/t
