Old 11-19-2002, 11:38 PM   #1
weasel29gm
SLOW BUT SURE,BUT CLOSER
Steering wheel ??'s
How far should a wheel go on the splines, I got one that has a wide base but the splines is offset to the bottom. When I put it on my column it looks like the shaft is half way on the splines. Is this enough? The threads showed thru the nut when tight. Just want to be safe. Thanks Weasel.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 11-20-2002, 12:40 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
As far as "just being safe"...as long as that nut is on there...you'll be OK.
Old 11-20-2002, 01:03 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Steering Wheel
Get at least a full nut on it to be safe.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-20-2002, 07:59 PM   #4
weasel29gm
Thanks guys!!!!!!!
