Old 09-27-2008, 09:31 PM   #1
jdodd68
jdodd68's Avatar
The 1968's Big Bang
So I am driving down the road... I start to climb a slight hill, and the truck started to hesitate when I tried to give it more gas. I tried to feather the gas pedal to attempt to work it out, but after that didn't work, I just tried pushing the gas more. That was when the sound resembling a shotgun going off shook the truck. At first I thought my motor had blown, but oil pressure was good; temp was good. The only thing I noticed was that my exhaust was louder. I pulled over and looked under the truck, and I saw one of my mufflers had ripped open. What would cause this? (As a sidenote: The truck is still hesitating after higher rpms.)
50th Anniversary 1968 Chevy C10 Custom LONGBED FLEETSIDE
350 out of a 70 chevy
Facebook
jdodd68 is offline   Reply With Quote
Old 09-27-2008, 09:52 PM   #2
68 short step
Re: The 1968's Big Bang
a major blockage in the exhaust would cause this, also does your state require cats on a 68 truck??/
68 short step is offline   Reply With Quote
Old 09-27-2008, 10:14 PM   #3
jdodd68
jdodd68's Avatar
No not in Indiana.
Facebook
Old 09-27-2008, 10:57 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
This can happen if there is unburnt gasoline collecting in the exhaust system. Is the engine running rich? Does it need a tuneup? Choke not opening up all the way? These are some things I would check. Timing could make it backfire but I don't think that it would blow the muffler out like that.
LockDoc
Leon
Old 09-27-2008, 10:59 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
When you where feathering the gas you loaded your muffler with raw fuel. At some point it was ignited by the hot gasses and exploded.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-27-2008, 11:23 PM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: The 1968's Big Bang
Sounds just like what happened to me with my 67 GMC, started to climb a hill and it just seemed to bog down and have no power, feathered the gas a couple of times then floored it and BOOM!!!! It blew apart my muffler, it turns out the spark advance went out, replaced it with a new one and never had the problem again!!!! So I would check that first!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-28-2008, 12:40 AM   #7
drivethechevy
drivethechevy's Avatar
others would know more then me but i had an s10 that the muffler exploded and looked quite a bit like the one in the pic afterwards, but what happend on the s10 was something pluged one of my pipes and it built up preshure in the exhaust pipe and it found the weakest point and made an exit
so id check the pipe for blockage past the muffler
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 09-28-2008, 01:29 AM   #8
bowtieboy93
bowtieboy93's Avatar
Holy hell
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 09-28-2008, 08:41 AM   #9
FormerMember
Check the other muffler for blockage...
FormerMember is offline   Reply With Quote
Old 09-28-2008, 09:24 AM   #10
pumpkin
pumpkin's Avatar
Sounds like an ignition problem. Under load it misses, which sends a perfect mixture for an explosion into the exhaust. Then is all it needs is something to ignite it, and boom goes your muffler. Best place to start is new plugs, wires, cap and rotor.
pumpkin is offline   Reply With Quote
Old 09-28-2008, 12:31 PM   #11
jdodd68
jdodd68's Avatar
Thanks for the info. I am going to check out the plugs, wires, cap and dizzy.
Facebook
