will it last another 5-10 years?
I see a lot of posts about roof sealer and problem caused by it. I never looked at seam sealer on my cab untill now. It's cracking bad but I am sure it was this way for a while. If I don't do anything about it do you guys think it will last maybe another 5 years or so?
Re: will it last another 5-10 years?
I would get a garden hose and run some water on your drip rail to see if you get water inside the cab.It looks like some of the cracks could take in some water.Just my 2 cents.
it's only get water when I wash it, once in a while. No leaks inside.
Resident of Here
Wow, yours is in good condition! Ours is barely left.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
member #16
![]() Join Date: Dec 1999
The only problem is rust between the top and roof. You wont see it until it comes through. I would consider some kind of temporary fix until you are ready to do the body work. If the truck doesnt sit out in the weather you are probably good for awhile.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Why do you need it to last 5-10. That is pretty vague.
67 3/4 Lwb Step side X San Diego County truck 70 3/4 berb was 402 Th400 Dana 60 now just the dana 70 3/4 lwb Fleet Choptop bagged th350 no eng yet 79 rx7 Wide body 350 TPI t5 flat black(The interceptor) 64 comet mounted on a 93 Thunderbird chassis. |
its all about the +6 inches
being that it rains in LA only once in a while, I doubt you'll have any poblems.
I bought a truck out of El Cajon and it had sun baked seam sealer there.It ended up with a rotted header panel inside.Why wouldn`t you just fix it?The sun belt trucks don`t rust like rust belt trucks and have lasted way better.But,your time is coming.Rustbelt trucks rust from the bottom up and yours will rust from the top down,just slower.I`d grind that out,get to clean metal,seal,prime,and paint with white paint.My truck from Modesto had totally cracked sealer,too.I fixed it before it made a bigger problem.We expect rust here and baby or trucks to make them last.You guys take it for granted because you`re unfamiliar with it.You may have a 50/50 chance of it not becoming a problem.But,I`d act on making it last forever.Why take a chance on letting another get too far gone?
At first I sought it was a bondo repair from the po. After reading here I know what it is. I am afraid if I touch the body it will turn in to a frame off restoration. Sometime next year I will get to it. Right now I am doing a motor upgrade with some suspension work.
![]() Join Date: Aug 2004
I'd clean that stuff out and reseal it. If you don't get a perfect color match on the roof, it's not that visible. By the time you notice rust coming thru, you'll have some major repair to do.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
![]() Join Date: Jul 2004
To hold our C20 till paint time, last year we masked it off about 3/4 inch from the edge and used some gloss white rustoleum and a brush to fill the cracks and seal it up until we can do it right. Looks good and no one has ever noticed the difference. Took 2 coats, one to seal and one to level it out.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
i would put a coat of white seam sealer on it till your ready to do the body work, that should last about 5 years
1967 LWB 4speed-current project ![]() 1970 LWB 3 speed -stolen ![]() 1980 Z28 - sold 1968 Barracuda Big block- sold ![]() 1969 Firebird 400/400-sold |
#13 |
i just used the standard drip or seam sealer in the regular calking gun. cost $8.00 to $10.00. use gloves to finger fit to my liking - let dry prime & paint pics
Trueman Last edited by 463; 09-28-2008 at 10:32 PM. |
#14 |
blood type; Retumbo
why settle for 5 to 10 years? I am looking for another 40 for mine.
#15 |
Pat
Do you have to put a thick bead of sealer on the drip rail? like it was stock
#16 |
I would.You want the water to flow out and not lay in there.I use 3M Body Seam Sealer and you can mike the paint into it.My truck is white and I chipped it out,used an abrasive fiber wheel,masked off the top and below,rust arrestor,sealing primer,removed masking on top,and spray bombed Gloss White spray bomb.I scuffed over the edges with a fine Scotchbright pad and liquid clay barred the whole truck just to preserve it until restoration.
#17 |
Just shave the drip rail, and then you don't have to worry about it
