Questions for Ls1 swap guys
I just finished up a LS1 swap in a 71 chevy truck and everything was working perfect exept my tranny wouldnt shift if you got on it hard, it would shift fine driving normal. well at the time my computer wasnt tuned yet so i figured it was that, Then the tranny went out so i put another one in it and took my computer to a guy and had my gear ratio and tire size changed and took all of the stuff i didnt need out. Well it is still doing the same thing, I am afraid of burning another tranny up. What else could it be, some kinda sensor or something , my computer is not throwing any codes, and the guy that did my computer does all the cars around here so i know hes good. Any kinda help would be great Thanks.
![]() Join Date: Jul 2006
Re: Questions for Ls1 swap guys
what tranny are you running? 4l60e or 700R4?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Sorry about that im running the 4L60E,
Call Jesse @
www.wait4meperformance.com and tell him what it is doing. Sounds like the speed sensor may not be acting right, but I am just guessing. |
you did hook up the TCC wire right???? its the purple one that goes to the brake switch...
also you have the BEST tuner local to ya, in warr acres, his name is glen (hope he is the one you are useing).... |
might be a question the guys over on the "Hybrid" forum on LS1tech can help you with. Lot more guys over there to pool from. One of them may have had the same issue.
Good luck! |
Yeh glen is the guy i am using, and yes i hooked up the brake light switch. I took it out today and drove it a little and its not that it doesnt shift, it actually gets to about 5500 RPM and the tranny just freespins, kinda like it throws itself into nuetral. but only at wide open, just cruisin it does fine
those sound ezactly like the symtoms of the TCC wire not hooked up, what year engine/trans are you useing? also whats it out of?
It is out of a 2000 SS camero, i am running a street and performance harness, I had a buddy put it on a scanner and it said my converter is locking up. That is the brake switch deal your talking about right
yea, thats what it controls, the lock-up of the converter.....any mil lights??? also did you install a cam??
its a bone stock engine, the only codes is a front o2 sensor,
hmmmm, my suggestion is to take it to glen, and have him ride along with you and he can monitor the eng/trans live and see whats going on.....
#13 | |
#14 |
![]() Join Date: Nov 2006
I don't know if it's the same on the cars, but on my 05 truck engine, I had to run a power wire to the transmission. It is part of circuit 1020 of my factory harness, so I just took that 1020 wire and ran it to a fused 10a pink hot lead and everything works fine. Something to think about?
The TCC is supposed to have 12v except for when stopping, so I used a 5-pin relay to switch the power from the TCC wire to the brake lights when I hit the switch. |
