Old 11-20-2002, 12:25 AM   #1
Alexis
Member since 2000
Alexis's Avatar
am i asking for trouble trying to snug.....
275/35/20 on a 20x8.5 inch wheels. it says for 9-11 inch width wheels. from edge to edge it's about 9inches but inside its 8.5. so what do you guy think.
dont want to have uneven size tire hieght so i think i'm going to try to put that tire size on all four corners. but i want to make sure i'm not going to fk anything up in the front.
Alexis is offline   Reply With Quote
Old 11-20-2002, 12:35 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think the 275 on a 8.5 inch rim will be ok...but as for putting them up front...I wouldn't hold my breath on it.
Just get 2 at first, and see if they rub. If thy do...go with a 255/30 or even a 255/25.
These tires will be easily damaged doing street duty in the real world with a tank ass truck on top of them.
Old 11-20-2002, 01:41 AM   #3
Dropt72Shortbed
Dropt72Shortbed's Avatar
alex,
the difference between a 245/40/20 and 275/35/20 is 1/10"
as for the 275/35 on a 8.5 im not sure
i ran a 275/50 on an 8" rim but the extra sidewall allows for that. with a 35 series tire it may be cutting it close since theres not that much sidewall to buldge.
Dropt72Shortbed is offline   Reply With Quote
Old 11-20-2002, 04:45 AM   #4
Ed ke6bnl
Originally posted by Dropt72Shortbed
alex,
I have 275 60's on 17 in for my truck not the chevy but my boy has 275 50 on 10in for his 70 chevy c10 looks good but we would go with the 17 I have for my 50 f1 Ford. If we were to do it again.
My boy mounts tires for the neighbor and you can probably get the tires on they use an extra air tank to force the tire on the bead. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 11-20-2002, 09:34 AM   #5
brad2
Think about a 255/35/20. It would fit the wheels and look good.
brad2 is offline   Reply With Quote
Old 11-20-2002, 09:34 AM   #6
brad2
Old 11-20-2002, 09:55 AM   #7
powder
the ring around my finger
powder's Avatar
wheels
hey man i have a buddy that has 18's on the front and 20's in the back and it looks good he put 18 up front so he will have enough clearance
powder is offline   Reply With Quote
