Old 09-28-2008, 06:17 PM   #1
renagadebee34
motors smoking!
i just put in my crate 350 and got it all hooked up and started it but now its smoking really bad! the motor hasnt been started in more than 2 years! smoking at first normal or should i be worried?
girls love guys like me!!!!!!
renagadebee34 is offline   Reply With Quote
Old 09-28-2008, 06:27 PM   #2
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: motors smoking!
Could have broken a ring when you fired it.. do a compression check. If it's carbed, a bad carb could be the culprit too.. might need a rebuild.
Albatrossian is offline   Reply With Quote
Old 09-28-2008, 09:40 PM   #3
oldgmc
oldgmc's Avatar
Re: motors smoking!
What color smoke black could be carb adjust white maybe water in the gas tank . How long did you run it
oldgmc is offline   Reply With Quote
Old 09-28-2008, 11:01 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: motors smoking!
Sounds like a carb or a ring problem? Did you get oil pumping through the motor or did you start it dry just curious?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-29-2008, 12:29 AM   #5
84 400
Sb 400 club
84 400's Avatar
Re: motors smoking!
or is it possible some one added oil to the cylinders to prevent rusting or sticking rings? With more information we could give you a better idea of what is wrong. Blue= oil, White= water black= raw or too much un-burnt fuel.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
