![]() Join Date: Sep 2008
Front & Rear Sway Bars
I bought Front & Rear Sway Bars for a 72 SWB fom Brothers. I have no factory mounting brackets. It appears that the front will hit the tie rods if install by the instructions. On the rear it appears that it will hang down to low and catch on everything. Please Help
Re: Front & Rear Sway Bars
Is your truck lowered?
Yes 4-1/2" in front and 5-1/2" rear
wanna be 67
for the rear you could have used a camaro sway bar cheaper and mounts high not low. Heres the link for that installation.....http://www.low69cst.freeservers.com/CamaroBar.htm For the rear sway bar I paid $45.00(ebay). Thanks low69cst
Restoration Virgin!
I bolted mine drirectly to the frame like in this thread....see post #42....http://67-72chevytrucks.com/vboard/s...t=72338&page=2
It'll tuck it up out of the way....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
I just installed mine from CPP (Classic Perform) they were a pain to install but once installed they came out awesome. The back does seem a bit low nut it is right there with the real differential.
I am posting some picts of them hopefully it will help.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Thanks for the info!
