Old 09-28-2008, 09:15 PM   #1
my67chevytruck
Under Construction
my67chevytruck's Avatar
crossmember /'s
Hello, i have removed the cab on the 67 to get ready for the front crossmember and rearend swap. I noticed that the PO rigged a AT crossmember in place. I will put the AT crossmember from the parts truck that originally had a BB. I noticed a bracket on the top of the trailing arm crossmember, is something suppose to be connected to it? i looked at the parts truck and it has a different bracket for the 2-piece driveshaft. I also notice that some rivets were cut on and looks like something was removed, does anyone know what was removed. Thanks .
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-28-2008, 09:28 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: crossmember /'s
that used to have a 2 piece drive shaft. the bracket is for the hanger bearing.
as far as swapping to a correct Xmember, will the exhaust clear?
those cut rivets must be toward the firewall area of the frame. the manual tranny trucks had a cross member there. the bell housing mounted to it.
68C15 is offline   Reply With Quote
Old 09-28-2008, 09:48 PM   #3
my67chevytruck
Under Construction
Re: crossmember /'s
Thanks 68 c15, i didnt even think about a manual crossmember, but thats what was removed, i will remove the rivets to clean it up. I was thinking of redoing the exhaust as the PO welded the headers to the exhaust tubing, and was thinking of installing the original AT crossmember from the parts truck since i have one . The AT crossmember that is in there now does not line up with the holes in the frame, so i could drill two holes and use grade 8 hardware to install. Any suggestions, or opinions are greatly appreciated.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-28-2008, 09:56 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
Re: crossmember /'s
personally I think I would leave that one in there. nice and simple. as long as the driveline angles are good and the mount doesnt flop around all is good. you dont really need grade 8. grade 5 will be fine.
