Old 09-28-2008, 10:50 PM   #1
CAMAROSS
CAMAROSS's Avatar
Bumper question
Not only the no start problem but I bought a new sport chrome bumper like the factory silverado one from LMC and got it put on. The only problem is the big gap between the bumper and the back of the truck. Gap is big and looks bad. Is there a panel that goes in here?
CAMAROSS is offline   Reply With Quote
Old 09-28-2008, 11:09 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Bumper question
Yes there is a filler panel that goes there.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-29-2008, 11:25 PM   #3
CAMAROSS
CAMAROSS's Avatar
Question Re: Bumper question
Anyone have a pic of what it looks like?
Old 09-30-2008, 03:53 PM   #4
Eighty-6
Re: Bumper question
I just ordered this same bumper and would like to see this picture as well. I wonder why LMC wouldn't have it on their catalog or on line.
Eighty-6 is offline   Reply With Quote
Old 09-30-2008, 05:24 PM   #5
CAMAROSS
CAMAROSS's Avatar
Re: Bumper question
Just found out that they dont have anything. The thing that we need is the bracket covers and Brother's said that they no longer have them. Looks like we are in a bind.
Old 09-30-2008, 05:38 PM   #6
suicide 63
Re: Bumper question
I just bought a bumper to ,i might try to drill the bracket and pull the bumper closer to the bed.That is when my bed is complete.
suicide 63 is offline   Reply With Quote
Old 09-30-2008, 05:42 PM   #7
suicide 63
Re: Bumper question
look at what i found classic parts #65-577
http://www.classicparts.com/1973-87-...ctinfo/65-577/
Old 09-30-2008, 05:43 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bumper question
Go to www.classicparts.com and order (2 each part) number 65-577. Originally there was a left and right bracket. In believe they have to be drilled to install. The last ones I got from GM,... only the left side was still available. I ordered 2 lefts and re-drilled one for the right side. Good luck.
Keith
Convert to disc brakes.
Old 09-30-2008, 05:44 PM   #9
lolife99
lolife99's Avatar
Re: Bumper question
Man,... I guess I type too slow. Yeah,... what he said,...
Keith
Old 09-30-2008, 05:57 PM   #10
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: Bumper question
Or you could just make your own out of some 16 or 18ga sheetmetal..
Albatrossian is offline   Reply With Quote
Old 09-30-2008, 08:11 PM   #11
OJOE
Crew Cut
OJOE's Avatar
Re: Bumper question
may not be for all but i think the only way the sport bumpers look good is do away with the fillers and pull the bumper in close. you can look at my crew cab build and see mine with out fillers. just my $0.02
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 09-30-2008, 09:18 PM   #12
CAMAROSS
CAMAROSS's Avatar
Re: Bumper question
OJOE, did you just drill new holes in the bumper brackets and move them in? Yours looks like what I want!
Old 09-30-2008, 09:25 PM   #13
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: Bumper question
HEY HOW BOUT SUM PICS OF UR TRUCK? POR PLEASE
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 09-30-2008, 10:00 PM   #14
CAMAROSS
CAMAROSS's Avatar
Smile Re: Bumper question
Will get some up asap. I have pics at the body shop in pieces and need to take some since she came home. Let me detail it and I will get someone on here (maybe you) to help me post them. Thanks,
Old 09-30-2008, 10:06 PM   #15
bigblock73
yeller
bigblock73's Avatar
Re: Bumper question
Those with LD leafs can get by with elongating the holes and sliding the brackets back to tuck the bumper, everyone else with HD leafs has to do the above AND trim the back of the brackets in order to slide them back.
bigblock73 is offline   Reply With Quote
Old 10-01-2008, 12:38 AM   #16
C-10volvo
C-10volvo's Avatar
Re: Bumper question
I ended up re drilling the bracket holes to move the bumper closer. One thing i may point out is that if you are running the stock moldings, they may get dented. My truck is shaved and only has about an 1/8 inch of clearance with the tailgate down.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 10-01-2008, 07:32 AM   #17
Eighty-6
Re: Bumper question
Does anyone have pics of the bumper installed with the filler panel installed?
Old 10-01-2008, 10:23 AM   #18
friscocrownie
Re: Bumper question
I've been wondering about this too, all I've found is the filler panels that seem to provide coverage for the mounting brackets and do not cover the gap all the way across, so I was thinking of making a full panel out of either ABS or Metal. I did find the part numbers for the panels at LMC:
30-3782 (LH) - $9.95
30-3783 (RH) - $9.95
friscocrownie is offline   Reply With Quote
Old 10-01-2008, 07:08 PM   #19
OJOE
Crew Cut
OJOE's Avatar
Re: Bumper question
i just moved mine in and welded in place. make sure you let down the gate to make sure it will clear. if you dont want to weld you can re drill and bolt on
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 10-01-2008, 07:11 PM   #20
OJOE
Crew Cut
OJOE's Avatar
Re: Bumper question
go to my build on this board-OJOES CREW CAB BUILD- should be lot of pics. thanks joe
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
