09-29-2008, 12:28 AM | #1 |
Zombie Killer
Can you identify this wheel?
This is the spare off my truck, it's different then the stock wheels on my 64. The back spacing is 3 1/2" which is about a 1/4" less then the original wheels. I did a disc brake conversion this weekend the the original wheels won't work but my spare works great! So I need to find more of these to run.
Some of the special markings are "K186 15 XX". I couldn't find any other part numbers??? I forgot to get a full front shot but it looks just like the originals. Click pics for bigger images. Thanks for any help....
1964 C10 Long Step |
09-29-2008, 02:39 PM | #2 |
Zombie Killer
Re: Can you identify this wheel?
anyone????? Any ideas...
09-29-2008, 03:24 PM | #3 |
Hey Y'all!!
I have no idea about the stampings but my guess would be that it is a later model rim. Hopefully someone more knowledgeable will chime in soon.
09-29-2008, 04:47 PM | #4 |
I did a little looking around the internet to see what I could find. There appears to be nothing significate about the rim except it is a rim rated for trailers (DOT-T)
I hope this helps.
1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
09-29-2008, 08:07 PM | #5 |
Zombie Killer
I've found where the issue is between the stock and the spare wheels is. On the stockers they have an inside diameter of 12", on the spare I have it has an inside diameter of 13". So if anyone has a line on some steel wheels 6 lug 15x6 w/inner diameter of 13" or more let me know. I'm having trouble finding anything.
Thanks Mike
09-30-2008, 09:34 PM | #6 |
The spare might be a 4X4 wheel. Try one for a 71 up they had disc and 6 lugs, so I'm guessing it would probably work.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391 42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392 96 GMC K2500 Diesel Suburban 89 GTA Trans Am Convertible. |
