converting 69 drums to 71 disk NEED HELP!
I am almost complete with my conversion and need some advice on proper assembly.
My truck is a 1969 C20, Custom Camper Special, with 350 and TH400, I've got a Dana 60 tracklock with 3:54 ring and pinion. The last thing to hook up is the steering linkage. I have the drag link (off the '71) all hooked up to the pitman and idler arms and I am stuck trying to figure out where the tie rods go. All 4 tie rods that came off the 69 are equal length. The tie rods for the '71 are different. 2 are short and 2 are long. I don't have a diagram to go by or instruction on which goes where. I assume one short one and one long one on each side. I assume the long tie rod is the inner since the zerk fitting is comeing right off the end of the rod and this would make it easier to access where the short tie rods have zerk fitting on the back of the "socket". If anyone can set me straight I'd really appreciate it. Also, any suggestion on the most sensible solution to solve the issue that my existing brake lines will not attach to the new '71 proportioning valve since the orientation and position is different. Make custom? or is there an off the shelf solution? Last edited by bowton; 09-29-2008 at 01:38 AM. |
Happy to be here
![]() Join Date: Mar 2000
Re: converting 69 drums to 71 disk NEED HELP!
Welcome to the forum bowton. Lets see if any of these guys can answer your questions.
#3 | |
As for brake lines, I would start w/a 71 C20 for 'pre-made' stuff (brake lines) or custom make the lines if you have the ability.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-30-2008 at 04:07 PM. |
Thanks Scoti for the information. I'm good to go and very excited drive it with disk brakes.
