"THE GREEN GOBLIN"
Ok another problem I have run into has anyone had this problem if so How was it solved ? I orderd A POWER STEERING-PRESSURE HOSE From LMC Part#32-1972 and it hits the hedder and the block so I can not tighten the POWER STEERING BELT Did I order the wrong one or is there some other hose you guys recomend? Or should I have this one cut and reflared? What are my options here? My Truck Is a 72chevy short bed 2wd originaly a 6cy Now a v8 454.. I took some pictures hope you can see what I am talking about for I have only a camera phone at the time!!! Thanks guys...
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
"THE GREEN GOBLIN"
Re: POWER STEERING-PRESSURE HOSE Help
Here is what the old one looked like unfortuneitly I tossed it out before matching it up with the new one! Dont ask me why I replaced it I know there was nothing wrong with it!! If it aint broke don't fix it right"lol"
Sierra Grande Club
I got one from NAPA that didn't come up that high. It was for a 2WD SBC (350).
You may want to grab one just to see if it will help. The crimp on it ended about where the frame edge is. Yours goes clear over it. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
"THE GREEN GOBLIN"
Sport/Truck What year was that for the you orderd Do you have a part # Just the year would be fine I guess thats all I would need To go to Napa and get one? Thanks
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 09-29-2008 at 06:53 AM. |
"THE GREEN GOBLIN"
No Luck Dean it's the same one I already have the only difference is the rubber part of the hose is shorter and it is made of aluminum VS mine is steel!
![]() ![]() ![]() The first picture shows the one I have and the one you have ! The second Picture shows what apears to look somehthing like my old one on the long bend on the bottom!!! What do you think?
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 09-30-2008 at 04:15 PM. |
its all about the +6 inches
I have one like that, and ended up bending it quite a bit to fit.
It looks to me like you could just loosen it up and angle it down. Might have to take the return line off. Or take the other end off from the gear box. Mine has a semi "loop" in it.
"THE GREEN GOBLIN"
It hits the block When attempting to tighten the belt the header isn't the only problem!!!
This is what I did. I had one custom made and then I ran it thru the chassis problem solved. I bought three different ones and none of them solve my problem. See picts....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Windy Corner of a Dirty Street
I wouldn’t even mess around with those Chinese aftermarket replacement hoses. They never seem to fit right. With all of my engine swapping, serp belt conversions, etc , I find it much easier just have a local hydraulic shop custom make the hoses to your liking so you can route them however you want. Custom hoses actually don’t cost much more than the Chinese repop aftermarket hoses. My local Napa store makes hydraulic hoses and A/C hoses. Check your local Napa and see if they can make you a custom set.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
