11-20-2002, 04:17 AM | #1 |
go bucks!
check your ground straps!
to any and all of you experiencing electrical prob.'s check both of the grounding straps on your trucks.searched high and low for a very simple problem that happened to be staring me square in the face! check the engine block to frame strap and also the cab to frame straps.took care of a "gremlin" i've been trying to track down for months!anyone w/ a battery that seems to not be able to keep it's charge,very likely it my be that the alt.is not being grounded through the engine block back through the frame.so basically you're battery isn't being recharged or kept at optimum power,and you're running on your battery all the time. these straps seem to be forgotten sometimes when doing an engine change or just plain getting old and brittle and breaking down over time.not exactly something you check very often!
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
11-20-2002, 04:53 AM | #2 |
Had a draining battery a few years ago. All the ground straps were solid but still got inadequate voltage going back to the battery. I rebuilt the alt, replaced the battery and voltage regulator and was still reading about 10 v across the battery. My solution was to cut out the middle man and run a heavy wire directly from the alt to the pos. battery terminal. Worked like a charm and haven't looked back.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
11-20-2002, 12:24 PM | #3 |
good advice. I just installed my engine, and forgot to hook up the ground straps that go from the block to the cab. I noticed the other day that the dash lights were doing some funky things, maybe getting around to hooking up the straps will help out.
11-20-2002, 03:31 PM | #4 |
Spank 'em if you got 'em!
Right now one of my ground straps is holding my plug cables off the exhaust maifold! Guess I should get some cable holder things and hook up my straps.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
11-22-2002, 03:39 PM | #5 |
A few months ago there was a post about ground straps and if I remember correctly, there are a total of 5 straps on 67-72's.
1972 C-10 LWB, 400/350, 2WD 1972 C-20 Custom Camper, 350/350, 4WD (Converted) |
