Best oil for a 292 I-6 in a 1967 C50?
I just purchased a 1967 C50 with a 292 I-6. Before I make the two hour trip home in it I plan on changing the oil. What is the best weight oil to use in this motor?
2004 GMC 2500HD 4x4 Crew Cab Duramax 2000 Chevrolet ext-cab Z71 1995 Chevrolet ext-cab Z71 1984 Chevrolet K10 6.2 4x4 1972 GMC Jimmy 4x4 1967 Chevrolet C50 Dump truck 1957 GMC 1/2 ton stepside (not running) |
Re: Best oil for a 292 I-6 in a 1967 C50?
10-40
Parts and more parts
The newer oils do NOT have the zinc additives that was used in the past. Unless you have upgraded your engines internals, then you need to consider the wear on the camshaft and lifters that is not being protected as they were. There are additives on the market that makes up for the missing chemicals in your oil, but it is pricey. Just something to think about....
its all about the +6 inches
and a side note... the zink additives, are probably more important than the make of the oil.
![]() Join Date: Sep 2001
I believe Rotella (Oil intended for diesel engines) has 1,400 to 1,500 ppm zinc which is similar to pre-catalytic converter low-zinc oils. Good Luck!!
Cantankerous Geezer
For additives, buy a bottle of assembly lube at the parts store. It contains the needed additives to keep your cam and lifters happy. Comp Cam has that on their website, but they recommend their own brand.
For oil viscosity, 10W-40 is not recommended for heavy duty use. It has been improved, but the polymers are not up to severe use. They still break down, just not as fast. Since you're in Tennessee, I will recommend 20W-50. I prefer the Pennzoil, it seems to adhere to metal better, but that's just my observation. 20W is a little thick when the temp gets below 10*F, so if you go north in the winter run 10W-30.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#7 | |
Cantankerous Geezer
I have seen some ads for oil blended for classic vehicles. I am recommending either that oil or assembly lube as an additive. Or put in a roller cam, but I can't see doing that in a C-50. ![]()
rotella has less zink than car oil does now.
Shell Rotella T which is a conventional (mineral-based) oil that was originally formulated for diesel engines. Rotella T still contains 1,200 parts per million ZDDP, according to Shell - which is as much as five times the amount found in other oils. Don’t sweat it that Rotella was/is "for diesels." It’s also an excellent choice for older, non-emissions controlled engines with flat tappet cams that need their ZDDP. Rotella’s also modestly priced and readily available at most any auto parts store. Shell also markets a synthetic version of Rotella that offers even more protection - as well as longevity and a 5W-40 viscosity for those who operate their vehicles in colder climates. Standard Rotella comes in a heavier 15W-40 blend.
Thanks for all of the replies. To provide a little more info, this truck has 90,000 original miles, and still runs good. I don't plan on driving it a lot (less than 750 miles a year probably) so cost isn't really an issue as far as oil, additives, etc. I'd rather put the best protection I can into it.
What would be the absolute best to put in it to insure the best protection and longevity from the oil? Rotella T plus an additive?
Anybody else? Can anyone tell me the oil capacity of this motor?
Resident of Here
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#13 |
ok i KENDALL oil sae 40 or 50
#14 |
My 292,in a 79 P-30 van takes 5 quarts and is a heavy duty engine.
Yours will take 5 quarts plus any extra required to fill optional large oil pan,oil cooler,large oil filter,etc.Some even have an air compressor mounted on the engine that use the engine oil for lubrication! Heavy duty engines are a breed of their own! Mike. ![]() |
#15 |
![]() Join Date: Aug 2001
i just rebuilt a 261 for my 60 c60. the machine shop made me promise to only run straight 30 and to run the comp cam additive during break-in.
79 K10 77 MGB 79 Kawasaki KZ1000 |
#16 |
I run the Rotella T in my aircooled Volkswagen with solid lifters, high spring pressure ect...I try to give it all the protection I can...some other VW guys use that plus the GM EOS "break in" additive for not only cam break in but put some in at every oil change. Theres also STP, I use it for assembly lube, I know it used to have high zinc content, not sure if it still does. I think if your worried about it, thats what I would do.
Sorry about the VW references, it's all I know (for now) as I'm new to the V8 world but we've had lots of cam/lifter failures so lots of oil/additive talk goes on.
71 Chevy 1/2 ton 66 VW bug |
#17 |
![]() Join Date: Oct 2006
Valvoline VR1 racing oil stil has ZINC in it. That is what I use in my 292,454,383. And around here it is the same price as any other oil.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#18 |
![]() Join Date: Jan 2007
I use Rotella to break in oour stockcar motors,I also us it on my 292 with a large small block oil filter. I run 20w50 untill it gets really cold then swap to 10w40.
#19 |
It is my unuderstanding that all diesel oils have had the zinc removed per the EPA.
BUT the VR1 by valvoline is intended for "racing" which means NO cat converter.which ever oil you decide make sure you use a QUALITY filter...WIX 51069. -Lance
#20 |
Here is a response from a Shell Oil Engineer from April 2008
Subject: RE: Rotella Ask Our Expert: Oil and Fuel Additives Richard, With the introduction a couple of years ago of ILSAC specification GF-4 and API specification SM for gasoline-only engine oils, the amount of phosphorous in the oil had to be reduced to prolong the life of catalytic converters. Zinc-based anti-wear compounds, like ZDDP, which also contain phosphorous, were reduced as well. These zinc compounds work well to protect flat tappet engines from excessive wear, so the modern gasoline-only engine oils are not as effective in this regard as they once were. Diesel engine oils don't suffer from the same requirements to protect catalytic converters, so the amount of zinc-based anti-wear additives remains high. Products like Shell Rotella T Oils, which also carry API S-series licenses for gasoline engines, have found favor for flat tappet engines. Shell Rotella T Oils contain about 1200 ppm zinc. That's at least 50% more of these anti-wear additives as most current gasoline-only engine oils, and about the same amount of zinc as API SJ-rated oils had in 2000. These levels of zinc have historically offered good protection for flat tappet applications. There are no proposed specification changes for diesel oils that would significantly impact the zinc content of Shell Rotella T oils over the next 2-3 years. Thank you for your interest in Shell Rotella Products! Regards, Edward Calcote Staff Chemist, Shell Lubricants US Technical Information Center http://www.rotella.com/ |
#21 |
![]() Join Date: Aug 2005
I use Valvoline VR-1 30W in the V-6.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
#22 |
KENDALL oil also has a sae 70 too i used KENDALL oil my dad used
it too his bothers and there dad they all used KENDALL oil evening in there lawn moreers too evening some of my friends useds KENDALL oil |
#23 |
Cantankerous Geezer
Your 292 holds 6 quarts with the standard filter, 7 if you have the 2 qt. filter.
With the info on Rotella I would run 15W-40. It is readily available.
#24 |
![]() Join Date: Aug 2008
I run Penzoil Platinum 10-30W Synthetic in my 292. It has been rebuilt with all new internals. I have read that this is one of the best synthetic motor oils produced. It out performs Mobil 1 in breakdown analysis tests. Wally-Mart sells it for $19.99 for a 5 qt jug. Here is a interesting link to Bob is the Oil Guy.com. Has everything you want to know about oils, lubes etc. You can send this guy a sample of your used oil for analysis, it will tell a lot about what is going on in your motor. Check out the forums also.
http://www.bobistheoilguy.com/index.html Here is a quote from Bob is the Oil Guy A lot of aftermarket additives use zinc and phosphorus for extra protection. The problem is, when you overload an oil with this type of additive, your oxidation levels tend to increase, causing an attack on the base oil, which in turn can cause an increase of viscosity, (thicken the oil) .This is why it is important not to play home chemist and blend in aftermarket additives that are not designed to be in the oil to start with. |
#25 | |
