09-29-2008, 04:38 PM | #1 |
Can you recommend great valve cover gaskets ...
for my sb with cheap crome covers? The fit is not that great and with cork gaskets there is oil leaking onto exhaust. I even used those flat metal pieces around the bolts to give them more bite on the edges. I'll try another set of gaskets and sealer (both sides) before I buy better fitting covers. BTW, it is a '68 327 stocker. Thanks again in advance.
09-29-2008, 04:43 PM | #2 |
Re: Can you recommend great valve cover gaskets ...
Mr gasket rubber gaskets #5860
Fel Pro rubber #1602
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg Last edited by lowriden58; 09-29-2008 at 04:45 PM. |
09-29-2008, 05:04 PM | #3 |
Lowriden,
What do like for a gasket sealer with those? |
09-29-2008, 05:08 PM | #4 |
i usually use black RTV silicone on the cover side only.
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
09-29-2008, 05:17 PM | #5 |
I'll givit a try and if that doesn't work I will be looking on the parts board for covers. Thanks!
09-29-2008, 05:27 PM | #6 |
I am a Referee of life.
Make sure you check the flanges.They can be bent or warped from overtightening.If you are very careful you can tap them straight with a small ball pein hammer.Often this is what causes the leaks.
Just a heads up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-30-2008, 11:48 AM | #7 |
I prefer Versa Chem brand Mega grey or Mega black. Those are gasket makers. Clean both surfaces with carb cleaner and paper towels. Then rub a thin layer into the head surface with your finger. That surface is very poreous and usually the root of the leak. Then a nice 1/4" bead on the valve cover with NO GASKET. Then put it on and let it dry overnight. BINGO!! No leaks EVER again. The only catch is if you have to remove the cover again it can take quite a bit of prying. That stuff adheres tenaciously!
09-30-2008, 02:37 PM | #8 |
72 chevys 4 life
just use a bit of weather stripping adhesive on the cover side and nothing on the other side its always worked for me
be sure to let it dry on the valve cover before you bolt that baby down!! Last edited by drewdude92; 09-30-2008 at 02:37 PM. |
