Bumper brackets...
Is there a difference between 1972 2wd bumper brackets and 4X4 brackets. Is there a difference between years?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Re: Bumper brackets...
Anyone?
The fronts are different, but the rears are the same.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Member #1049
Lets see if I remember.. There are 4 different types of front bumper brackets... 67-70 2WD Chev or all 2WD GMC... 67-70 4X4. Chev or all 4X4GMC.. 71-72 2WD chev.. 71-72 4X4 Chev...
The rears are the same between 2WD and 4X4 long box. Then leaf spring 2WD short box and short box 4X4 and 69-71 Blazer are the same.. 72 Blazer uses only outer rears.. and Suburbans use only outer rears.. |
My answer was for the 72 only. I missed the second question. On your 72 you will need to use the front outer brackets from a 71 or 72 2 WD on the front. Rear outers from any year will work.
Jim
