Axle Swap
Okay.. lookingto swap in a G80 axle hopefully with GT5(4.10) or HC4(4.56) ratios. Question is though, will it bolt up to a '68 C20 or will it need to be modified a bit? I'm a bit of a newbie when it comes to a custom drive train.
1968 Chevy C20 357/350 May the crabs of a thousand Las Vegas hookers infest the crotch of the person who fu<ks up your day, and may their arms be to short to scratch. Last edited by Longhorn Man; 09-29-2008 at 08:56 PM. |
its all about the +6 inches
Re: Axle Swap
Not sure where you are getting your option numbers, nor what exactly it is you hope to swap in...
the RPO G80 is an overload spring. 4.10 gear is option HB8 4.56 ratio is option H20 What rear do you have now, and what are you wanting to put in there? |
Truck and auto performance nut
Re: Axle Swap
G80 is the late model RPO for a GM locker, with the GT5 and others being for ratios dependent on model.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: Axle Swap
I to would be interested in info on this. I have a 68 C20 also. I know you would have to weld perches for the trailing arms.
