Old 09-30-2008, 11:07 AM   #1
Greenlee
Greenlee's Avatar
A/C fan only works on high...
I think i have read about this problem before, but I had no luck with a search of the forums. My fan only blows on high. It does nothing on low or medium. I replaced the fan itself about a year ago and it has been working fine until now. Anyone have any idea what the problem is?
Greenlee is offline   Reply With Quote
Old 09-30-2008, 11:12 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: A/C fan only works on high...
Sounds like the switch. Mine works in every position but high.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-30-2008, 11:14 AM   #3
jchav62
1962 C-10
jchav62's Avatar
I had this same problem on my '83. I asked my brother in law, who's a mechanic, and he said it's the switch that causes these problems. I never fixed it on my old truck, but he has done a few. Replace the fan switch...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-30-2008, 11:17 AM   #4
Trimman
Trimman's Avatar
Mine did that not to long ago. Check the resistor, it's mounted on the evaporator box. Mine was coroded cleaned it up works fine now.
82 C-10 Scottsdale LB owned since 89
350 crate vortec heads Crane 1.6 full rollers
edelbrock 1406
edelbrock performer eps intake
dynomax headers/flowmaster 70's
BTO 700r4 level 3
custom 2 piece driveshaft
12 bolt gov loc w/3.08
Trimman is offline   Reply With Quote
Old 09-30-2008, 12:29 PM   #5
Square84
I don't think these pills work
Square84's Avatar
x2 check the resistor it controls the lower speeds of the fan your high speed is wired directly to a power source so even if the resistor is bad the high will still work
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 09-30-2008, 02:48 PM   #6
abebummy26
abebummy26's Avatar
I agree with Joe its the switch. My car did the same thing on the lower 2 speeds, one of the resistors (I think) inside it went bad.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 09-30-2008, 02:51 PM   #7
COMP
they aren't in the switch on mine
COMP is offline   Reply With Quote
Old 09-30-2008, 07:39 PM   #8
f.monroe
f.monroe's Avatar
What year truck ? My 73 Cheyenne only blows on high if the temp control lever is all the way over to cold . If you back it down a little , you feel a click and then the fan can be run in any speed . The owners manual says that this is how it is suppose to work .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-02-2008, 02:19 PM   #9
Greenlee
Greenlee's Avatar
Frank
It's a 1976 Silverado. I am planning to check out everyones suggestions this weekend and see if I can figure out what's wrong with it.
