Old 09-30-2008, 01:59 PM   #1
Ackattack
Ackattack's Avatar
Lets talk about distribution blocks!
So I'll be running disc brakes on all 4 corners and need a distribution block. I have a few floating around. One is from a 72 3/4ton (so front discs, rear drums). The other one is from my 68 C10, but it had disc brakes on the front when I bought it. So I don't know if this one is a drum-drum or disc-drum distribution block.
I want a drum-drum distribution block. Are there any identifing marks on the blocks to be able to identify them?
Ackattack is offline   Reply With Quote
Old 10-01-2008, 11:08 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Lets talk about distribution blocks!
Bump.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-01-2008, 11:51 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
Are you talking about a proportioning valve? And why run drum-drum when you will have 4wheel disc? CPP sells a disc-disc prop valve.
Frizzle Fry is offline   Reply With Quote
Old 10-01-2008, 02:05 PM   #4
Ackattack
Ackattack's Avatar
Isn't the block that is right under the master cylinder the distribution block?
My thinking is that a disc-drum has bias built in to actuate the brakes correctly, where as the drum-drum doesn't bias it any and therefore will work with a disc-disc setup.
What distribution block (or proportioning valve if that is what its called) are you running Frizzle?
Old 10-01-2008, 02:06 PM   #5
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Put a Wilwood valve on and call it a day - it looks trick, works well and costs less than an OE set up
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 10-01-2008, 08:09 PM   #6
uno67
uno67's Avatar
I think your on the right track, i remeber hearing something about if you have 4 wheel disc you can get away with using the distribution block from the 4 wheel drum application.
uno67 is offline   Reply With Quote
Old 10-01-2008, 08:21 PM   #7
Ackattack
Ackattack's Avatar
ya know, now that I think about it, and read 1968SWBBigBlock's post, maybe I don't even need one. Just put an aftermarket porportioning valve on it. Maybe I'm trying to over complicate it.
Old 10-02-2008, 01:24 PM   #8
Frizzle Fry
http://www.classicperform.com/Store/...ruck/PVKS2.htm
