09-30-2008, 05:08 PM | #1 |
WTB: Steel wheels
Looking for (2) 15" X 10" 6-lug steel wheels to fit my '68 stepside (rears) with rear drums. I am looking for ones with the correct BS to fit with (almost) no modifications, if there is such an animal. I don't need trim rings or beauty rings. I am located in central Texas.
Thanks, S.C. |
09-30-2008, 05:23 PM | #2 |
67-72 parts collector,…
Re: WTB: Steel wheels
I would check out Wheel Vintiques. They should be able to build whatever you want. I'd stick with a 4.5" to 5" backspacing. BUT,... measure yourself before you order.
09-30-2008, 11:17 PM | #3 |
Saving 1 truck at a time!
I have the 8" wheels on my stepside with bags...they rub the outside of the fender and have minimal clearance inside against the box. I would be very careful with the 10" wheel. My 8" have 4.5" back spacing and I am running a 265 x 70 x 15. I had 275 x 60 x 15 and they rubbed badly when I tried to tuck the tread under the fender lip.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
09-30-2008, 11:23 PM | #4 |
"Trucks with Class"
Like stllookin said, there isn't much room on a stepside. I don't think 10s will go without wheel tubs.
10-01-2008, 09:55 AM | #5 |
Thanks for the info!!
FYI - Tubs don't bother me, I just don't want to modify the axle. I plan on tubs at some point anyway. I am looking to run 325/50/15 tires. Last edited by SCIV; 10-01-2008 at 09:56 AM. |
10-01-2008, 08:22 PM | #6 |
newly minted old timer
me too, but i need the 8 lug. ill keep an eye out for you though
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
