Old 10-01-2008, 07:05 AM   #1
D13
D13's Avatar
New cab mounting hardware
I have an 84 running chassis. I think I've found a 86 cab for it. The problem I have is cab mounting. I'd like to put the PST polygraphite cab mounts on it, but they require reuse of your old hardware. Since I have a bare cab and chassis I don't have the cups, sleeves or bolts. LMC will sell me the bolts as part of the mounting kit, but I really don't want the rubber body mounts. Does anyone sell the bolts seperate? And am I basicaly on a j-yard search for cups and sleeves? Or am I missing something? Thanks!
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-01-2008, 10:34 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: New cab mounting hardware
you can use grade eight bolts from any hardware store the cups and sleeves youd have to buy elsewhere
do you have pics of the cups you need?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-01-2008, 10:54 AM   #3
D13
D13's Avatar
No, I'd have to disassemble one of my complete trucks for that, and I'm not quite up for it. Any guesses on the bolt size? I want to say someone said 1/2" x 3 1/2". Are all the cab and rad support bolts the same?
1987 2 ton
Old 10-07-2008, 05:27 AM   #4
D13
D13's Avatar
Bolt size anyone? Cup and sleeve source? Donations?
1987 2 ton
Old 10-07-2008, 07:07 AM   #5
bigblock73
yeller
bigblock73's Avatar
If you get the PST kit, all you need are the bolts. My PST kit came with everything except the bolts. I have a set of bolts that I am keeping for the cab swap on my 77, but can measure them for you late tonight when I get home.
bigblock73 is offline   Reply With Quote
Old 10-07-2008, 10:48 AM   #6
old Rusty C10
lemme look downstairs how many bolts do you need?
Bob
I hate cancer!!
Old 10-07-2008, 10:53 AM   #7
bigblock73
yeller
bigblock73's Avatar
There are 4 for the cab
Old 10-07-2008, 11:12 AM   #8
old Rusty C10
jeff the bolts themselves are the same between the two cab styles right?
Bob
I hate cancer!!
Old 10-07-2008, 12:14 PM   #9
bigblock73
yeller
bigblock73's Avatar
They should be, unless they went to metric sometime in the 80's
Old 10-07-2008, 01:39 PM   #10
D13
D13's Avatar
Ah, I revisited the PST site and see they include washers and sleeves. The 'must reuse existing hardware' is what threw me. I found one cap on an old mount , it's a cup-shaped washer about 4" accross, seems to go on the top between the rubber and the cab. But it looks like the PST kit has new flat washers in it.
Assuming that the rad support uses the same, I'd need 6 bolts. If someone can get me the measurement it's probably cheaper to buy them locally then have them shipped.
Thanks, Roland
1987 2 ton
Old 10-07-2008, 08:51 PM   #11
old Rusty C10
this is what i have in the basement.. im not sure if its from the 76 i had or the 81 thats also gone but hey pieces of it live on in the basement
i can prolly go down there again in the morning and measure the bolts for you
Bob
I hate cancer!!
Old 10-08-2008, 04:17 PM   #12
D13
D13's Avatar
That would be great. THen I'll step up and buy the PST kit.
1987 2 ton
Old 10-08-2008, 07:49 PM   #13
old Rusty C10
Bolt length ( including head 4")
Bolt shaft length3 1/2 "
bolt shaft width 1/2"
Head size 3/4"
Coarse thread 13 thread per inch
Id use grade 8 bolts personally
Bob
I hate cancer!!
Old 10-09-2008, 06:54 AM   #14
D13
D13's Avatar
Many thanks!
1987 2 ton
Old 10-09-2008, 08:21 AM   #15
bigblock73
yeller
bigblock73's Avatar
Theere are 2 different bolt lengths. I forgot to measure them last night, will do it tonight...promise.
Old 10-09-2008, 11:48 AM   #16
old Rusty C10
Originally Posted by D13 View Post
Many thanks!
hey thats what we are all here for
Bob
I hate cancer!!
Old 10-14-2008, 01:03 PM   #17
D13
D13's Avatar
2 different bolts?
now I'm all confused again....
1987 2 ton
Old 10-14-2008, 03:39 PM   #18
Prong
The rears will be longer than the fronts...
Prong is offline   Reply With Quote
Old 10-14-2008, 09:22 PM   #19
bigblock73
yeller
bigblock73's Avatar
OK, measured the ones off the 78 GMC cab I removed.
2 @ 6 3/4"
2 @ 4"
Hope this helps you on your way.
