Old 10-01-2008, 09:46 AM   #1
olskoolchevy
olskoolchevy's Avatar
Mounting Gauges Behind Bezel?
I'm ready to start building my gauge cluster and I think I want to mount the gauges behind the bezel. Any hints or instructions on how to do this, what I need to do this, and is there any specific gauge to use or stay away from?
Joel
olskoolchevy is offline   Reply With Quote
Old 10-01-2008, 10:26 AM   #2
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Mounting Gauges Behind Bezel?
I did this on my truck for the temp and oil pressure gauges... Will be doing the tach this winter. I used Autometer Sport Comp II short sweep gauges which look very similar to the factory ones.
Here is how I installed them: Removed the bezel and lense from the front of the gauge. I then used the gasket from the inside of the bezel and glued it to the outer ring on the front of the gauge. This sits up against the back side of the factory tin. I carefully cut a hole in the back tin just barely enough to fit over the gauge. Then, I used the supplied plastic mounting rings but instead of attaching it to the back of the gauge, I cut it down to fit inside the back tin. When the back tin is attached back in place, it holds the gauge against the face of the cluster.
I think they turned out really good... Without telling people, they don't even notice they're not factory.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 10-01-2008, 11:19 AM   #3
Hart_Rod
Hart_Rod's Avatar
There's an article in the FAQ's that shows exactly how to do it.
Hart_Rod is offline   Reply With Quote
Old 10-01-2008, 11:26 AM   #4
olskoolchevy
Oh great, anytime someone puts "carefully" in a set of instructions, it usually costs me a little extra money and a couple of extra attempts. Thanks guys.
Joel
Old 10-01-2008, 12:16 PM   #5
el curioso
el curioso's Avatar
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 10-01-2008, 02:35 PM   #6
cameeks
Long Fleet Club
cameeks's Avatar
Here are two links of what Putter did.
LINK
LINK
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 10-01-2008, 05:33 PM   #7
Hart_Rod
Hart_Rod's Avatar
Here's the link I was talking about:
http://67-72chevytrucks.com/vboard/s...d.php?t=110613
Old 10-01-2008, 06:33 PM   #8
D'Animal
WOW! Thanks for the Link!
I was going to post up where to get a gauge pod for some "Extra" gauges. You just solved my problem.
D'Animal is offline   Reply With Quote
