Old 10-01-2008, 03:32 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Bag brackets for the front.
I know this has been asked, but i cant find it anywhere. Its probably alot easier then i think but how do you mount the front plates for the air bags and the cups???
I have found articles on this before in the past and now that i need it, i cant find it again. ahaha..
Here is a pic of the brackets and cups im talking about.
lyrikz is offline   Reply With Quote
Old 10-01-2008, 03:45 PM   #2
71tahoe
71tahoe's Avatar
Re: Bag brackets for the front.
The cups will just bolt to the bottom of the bag.
The best way I found to mount the plates is to clamp them to the crossmember and center punch through the 4 mounting holes. I had a piece of vacuum tube over the punch and wrapped electrical tape around that until it was about the same size as the hole in the plate. Centered up nicely. Remove the plate and drill a smaller pilot hole first then drill the 7/16 hole for the bolt. Watch out for brake lines and hot shavings.
It's possible to just drill through the holes in the plate but I didn't want to chip the powder coat off. It is a lot easier if the lower control arm is off the truck and you will probably have to remove the steering-stop anyway so yank 'em.
71tahoe is offline   Reply With Quote
Old 10-01-2008, 03:47 PM   #3
lyrikz
PITbut
lyrikz's Avatar
So the cup bolts to the lower control arm and the bag bolts to the cup?
I figured it was so easy. thats why i couldnt find info. ahah
Old 10-01-2008, 03:50 PM   #4
71tahoe
71tahoe's Avatar
The cup just bolts to the bag and sets in the spring pocket in the LCA. I'll look to see if I have a picture.
Old 10-01-2008, 03:52 PM   #5
jkaylor68gmc
jkaylor68gmc's Avatar
that's it, whose kit did you get? It looks nice.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 10-01-2008, 03:59 PM   #6
lyrikz
PITbut
lyrikz's Avatar
Thats not my kit, just identical to what i have. Its SD,s control brackets and cups....
